Question about Kenmore Washing Machines
Washing machine will fill with water, but won't articulate
I have a kenmore 70 series washing machine that will fill with water and won't articulate what is the problem?
  • Michael Masters
    Michael Masters May 11, 2010
    articulate?? Do you mean,agitate?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
I assume that you mean after filling, it won't begin the agitate cycle.
If you can hear the motor but the agitator won't move, it could be the "motor coupling". (See the motor section of the Sears site. This coupling is a fail safe between the motor and transmission. If the plastic prongs break, or the rubber center piece wears out, the transmission cannot agitate the washer.
If you can't hear the motor, it could be a timer problem.
Try to manually move the timer to a spin position and see if the motor / transmission move. If they do, it is most likely a timer.
Posted on Sep 26, 2009
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
The wash machine will fill but wont stop filling
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Dec 28, 2009 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
70 series wont fill w/water
CHECK SCREENS IN WATER VALVES FIRST. CHANGE TEMPERATURE SELECTOR TO COLD ONLY, SEE IF IT WILL FILL. IF IT DOES FILL AND SCREENS ARE CLEAN YOU MOST LIKELY NEED A WATER SELONOID.
FXIT
Jan 26, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
143 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
