Question about Microsoft Xbox 360 Console
3 red lights on xbox 360 - Microsoft Xbox 360 Console
What is the Red Ring of Death?
When Microsoft designed the Xbox 360, they attempted a innovative method of mounting the heat sinks to the motherboard. During normal operation, the temperature within the case is very hot. Which in turn causes the motherboard to flex against the x clamps. It is this flexing, which results in the soldered joints around the processors coming away from the motherboard. The fault is indicated by the now infamous 3 red lights!
Recent Xbox 360 Elite's have been upgraded with a stronger epoxy resin to glue the processors down. Whether this will work, only time will tell!
The X Clamp fix
The modification detailed in this guide, alleviates the flexing of the motherboard and maintains uniform pressure on the processors, this in turn ensures the heat sinks are far more effective in dissipating the heat build up.
Kit list
Torx Screwdrivers T8 & T10
Pliers
Artic Silver Thermal Paste
Thermal Paste cleaner (nail varnish remover!)
Thin flat bladed screwdriver
8 m5 10mm bolts
8 m5 steel spring washers
24 m5 1mm width washers
Step 1 - disassemble the console
Stop and take a look at your warranty, is it still in date? If so contact Microsoft for a replacement! If not, then proceed.
Remove the front face plate by placing your thumb into the USB door, applying pressure on the side panel, you will be able to lever the cover off. Do not force it!
Once removed this will expose the Microsoft warranty sticker. Next, we need to remove the side panels.
They are kept in place by 3 lugs on each side, which can be seen by looking through the ventilation holes. Using the thin screwdriver (or wooden skewer), push the lugs through the holes, whilst gently levering the grey side panel up. Once you have released a couple the panel will lift up quite easily. You will have to remove one of the rubber feet, to access one of the lugs and the hard drive if you have one.
Once both panels have been removed, we can move onto the case itself. On the rear of the case are 6 retention slots and 4 clips on the front of the case.
Unclip the front clips using the thin screwdriver, and gently lift the front up about an inch.
Now locate the rear 6 retention slots, and again using the thin screwdriver, push gently into each slot, you should hear a click each time.
Once all 6 have been released, you will be able to lift the top halve of the case off.
Flip the console over, and you will notice 14 silver screws and 8 black screws, remove these using the Torx screwdrivers.
Once all removed, turn the console over and remove the case.
This will expose the motherboard and DVD drive. To remove the DVD drive, simply lift upwards and unclip the cables from the rear of the drive.
Now you will have access to the white plastic fan shroud, which lifts out by unclipping the retention hook at the top of the shroud. Unclip the cable to the fan.
At the front of the console, you will notice a daughter PCB, by the power button. Unclip the white power button cover and remove the 3 screws with the T8 screwdriver.
Unplug the daughter board, this will enable you to lift the motherboard out carefully.
Once you have the motherboard out, you will notice on the underside 2 x clamps.
To remove the x clamps, you will need to pry the clamps off the metal studs. Insert the thin screwdriver into each corner of the clamp, gently levering each one until they are released. If you do 2 corners at a time, it is easier. Take your time, it is essential we do not damage the motherboard.
Once the clamps are removed, flip the motherboard over and gently remove the 2 heatsinks by lifting them up. The low profile one is the GPU heatsink, the main cause of the problem!
Using the Pliers, or small spanner, remove the four bolts on the underside of each heat sink. The bolts are no longer required.
Now we need to remove all traces of the old compound from the heat sinks and processors. Start by using a plastic scraper, usually supplied with the thermal paste or an old credit card! Take extra care when cleaning the processors.
To remove the remaining compound, use the nail varnish remover or if you have it compound cleaner, only a little is required.
With the processors, we are trying to obtain a mirror finish on them!
Now apply a little dab of compound to each processor and spread with the plastic card, we want a thin film across the top of the processor, no more no less.
Now we start the process of re-fixing the heat sinks.
Place a spring washer on each bolt (m5 10mm) followed by a steel washer, insert the bolt through the underside of the motherboard and then place 2 steel washers on the bolt. It is essential we have the correct width between motherboard and heatsink.
In order for the bolts to stay in place whilst attaching the heat sink, I stand the motherboard on its side and screw the bolts in a couple of turns until they have purchased.
Once all 4 have been attached, we need to systematically tighten each bolt, so start top right, then bottom left, bottom right and top left. This ensures the heat sink is uniformily tightened and not one side at a time. Repeat on next heat sink.
We can now plug everything back in, apart from the fans.
Turn the console on, we want it to overheat in order for the changes we have made to reset. Looking at the power bottom, wait for the 3 red lights to go to 2 red lights, this could take a couple of minutes. Once we have 2 red lights, leave the console on for about 5 mins.
Now turn the console off and let it cool down for about 1 hour.
Now we come to the test, plug everything back in including the fans and turn the console on. You should now be looking at green lights.
If you have green lights, re-assemble the console.
If you have red lights, we have a couple of procedures to follow, do not worry, some consoles take a number of attempts before the fix is successful.
First, loosen the screws holding the heat sink in place and with the fan disconnected run the console with 2 red lights for another 5 minutes, then allow to cool.
Once cooled try the test again with everything plugged in. still getting red lights?
Check the thermal compound is not too thin on the processors and before tightening the screws up, run the console again for 5 minutes with 2 red lights. Tighten screws up and allow to cool. Run the test again after an hour. If you still have red lights, run the console again with the fan disconnected for a longer period of time on 2 red lights, before allowing to cool.
It is normal for the console to take about 3 attempts to get all green. If none of the attempts work, gone back to the beginning and start again. Do not give up, this fix has been 100% successful for me.
Once you have green lights and you have put everything back together, run another test to ensure you still have the green lights, remember you will not need the 8 black screws for the case.
It is advisable, to run the console on low settings for about 20 days and keep it well ventilated. Fan upgrades are available, which run more efficiently.
For more detailed instructions and video's visit: http://bestxbox360repairguides.com/
Enjoy your Xbox!
Steve Thornton offers insight into the information product market, researching a number of niche topics and resourcing products in those areas.
Please take time to visit the estore at: http://www.lobbythornton.com/estore
Article Source: http://EzineArticles.com/?expert=Steve_Thornton
Posted on Sep 27, 2009
SOURCE: red light on my xbox 360
Turn console of, hold sync button down wich is the small white button next memory card slots, while holding turn on console and wait till it boots. If this does not work go to system blade, select memory, press y on the HD symbol, press xx left bumper right bumper xx, select yes. This will restart your console from scratch though all profiles and saved data will be lost, but it will clear any corupt data.
Posted on Sep 16, 2007
ryanriopel28
  • 130 Answers
SOURCE: xbox 360
Send it in to Microsoft. They'll fix it for free. "If a customer has an issue indicated by the three flashing red lights, Microsoft will repair the console free of charge -- including shipping -- for three years from the console’s purchase date."
http://www.xbox.com/en-CA/support/petermooreletter.htm
Posted on Dec 04, 2007
  • 10 Answers
SOURCE: As playing Xbox 360 system shuts off two red lights occurs.
Two red lights mean your 360 is over exceeding the inside temperature. Your fan must not be working at all and your 360 is overheating tremendously. That is what I know about the 2 red lights. Im not sure what to tell you to fix this but to just call 18004myxbox.
Posted on Mar 15, 2008
SOURCE: fix xbox 360
the famous red ring of death caused by overheating stick a fan behind it!
Posted on Jul 15, 2008
SOURCE: xbox 360
The 3 red light error is a CPU and GPU chip error that overheats.
Nearly all of these problems are caused by overheating and you can fix them yourself.
I used the blog below to fix mine and it took about 40 mins:
http://xbox3603redlights.wordpress.com/
Posted on Nov 02, 2008
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
Xbox-360 elite lower right hand red flashing led light code error E73
Jan 17, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
One red light on xbox 360
In most cases If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages.
HERE IS THE RED LIGHT REPAIR MANUAL: http://docs.google.com/viewer?url=http%3A%2F%2Fpdftown.com%2Fpdf-ebook%2FXBOX%2520360%2520Repair.pdf
Oct 19, 2009 | Microsoft Xbox 360 Console
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
Sep 20, 2009 | Microsoft Xbox 360 Console
Xbox 360 repair in mumbai :- 9819767710/9867635653 ?
HELLO ALL GOOD NEWS FRIST TIME IN INDIA
XBOX 360 3 RED LIGHT ? NO PROBLE CALL ME NOW
WE ARE PROFESSIONAL ALL TYPE OF VIDEO GAMES REPAIRING. NOW WE HAVE NEW SOLUTION FOR XBOX 360 3 RED LIGHT FIX. WE CAN FIX 3 RED LIGHT PROBLEM WITH GUARANTIED.
NOW WE CAN PROMISS U FOR YOUR XBOX 360 VERY EASY NEVER BECOME 3 RED LIGHT PROBLEM. NOW WE HAVE VERY GOOD SOLUTION FOR 3 RED LIGHT.
IF YOU WANT BEST SERVICE AND SPECIALIST REPAIRER FOR YOUR ALL TYPE OF VIDEO GAMES.
PLS FEEL FREE CONTACT US
MAHBOOB ALAM & SERAJ AHMAD
MOB : +919867244969
EMAIL : mahboobidrishi@hotmail.com
Website : http://sonyservice.en.china.cn/
Jan 23, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
Mar 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
159 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
