Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
Toro deck mower problem. Why my mower is using excess fuel?
Problem with 2008 Toro deck mower?
What is the reason that my mower is using excess fuel?
  • 437 Answers
Carburetor may need adjusting. The fuel you use may have an ethyl alcohol content low enough that the gas stations may not be required to post on the pumps. I know most of our fuel in this area has at least 10 percent ethyl alcohol in it. This makes fuel burn cleaner but you also use alot more fuel.
Posted on Sep 26, 2009
Toro 52" need a spindle shaft for the deck,part no.78-6710 hard to find & very expensive,maybe there is some used ones around the countryside in Oz on a retired mower deck?
there is three on ebay by your part number. Toro Wheel Horse Mower Spindle Shaft 78 6710 $54 is about average for this type of repair. But if yours is straight and just wore at the bearing area you can JB Weld it back to size .
May 14, 2016 | Toro Garden
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
I need a diagram for toro deck 30753
Hi
I have located both the owners manual and a parts manual with breakdowns of all the components of your Toro 52" Groundsmaster mowing deck.
Both can be downloaded from Toro directly at the following link;
Toro 52" side discharge mower, Groundmaster 120 Toro Direct link.
I hope this helps you and if you have any further needs, please feel free to ask.
Jul 11, 2014 | Toro Garden
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
RE: 42'' zero turn Toro with Kohler 19 hp. Ever since I bought it new, it has used oil, I am very dissatisfied with it. Model 74360 Serial #270000001. The starter relay doesn't work correctly. It will not...
Toro is a great brand, but the Home depot models are for home use. IF it won't start correctly you should troubleshoot the problem as this is a built in safey system for your benefit. There is a switch on both parking breaks, A switch to detect you sitting in the seat. The PTO must be disengaged. Check each of these. If you have your manual you can view the schematic diagram, and test each switch. If not, you can download a manual from Toro web site. According to your model and serial number your deck would only have two blades. They also have what they call "blade stiffeners" . Your results from buying power equipment from a big box store is typical. If you need service, pay a little more, and buy from your local power equipment distributor.
Jul 12, 2010 | Toro Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
How do I replace the belt on my toro model 20334 lawn mower
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from comming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Sep 03, 2009 | Toro Lawn Mower With Toro Power Tools
Replacement blade position.
The blades have such a close tolerance tip to tip on a V belt deck that it makes no difference where they are positioned, On a 3 blade deck the center spindle is forward of the two outer spindles. So for that reason you still get a quality cut. Most all commercial units use a V belt and have a good quality cut.
Some john deere mowers have a timing belt with cogs like a car and their blades have to be in time
90 degrees perpindicular to each other and locked down and if you strike something then the timing will be off and your back working on your mower instead of cutting grass,and the belts are twice as expensive than a v belt.
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
119 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
