Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My rider mower have to be jump started and once i start cutting for about 3 minutes it will shut off and have to be jump started again and the battery will not keep a charge.
  • 80 Answers
The battery will need to be replaced.
John
Posted on Sep 29, 2009
Engine shuts down when cutting deck engaged
This is probably due to a misadjusted or faulty safety switch on the rider's seat. There is a deadman switch there that will shut down the mower if the rider gets off the seat with the blades engaged.
Mar 06, 2015 | Garden
Walker mower
Your ignition switch is bad. The contacts inside are not making good connection to send signal to starter solenoid to start engine. Now the run position contacts are bad causing the engine to shut off. If the engine cuts out on you again, wiggle the key in the ignition at the same time start the engine using your screw driver. If the engine starts back up again, wiggle the ignition to see if the engine hesitates and stalls out again. If so, replace ignition switch assembly.
Sep 25, 2013 | Garden
I have an MTD Rider with 18hp Briggs that stops running after about 20 minutes. Last time it died I turned the key and nothing happened. I have replaced coil, silonoid and key switch still nothing. I...
if you need to jump the solenoid to start it and it shuts down sounds to me that you have a bad safety switch start with the one on the pedal
Apr 29, 2012 | Mtd Garden
I have a YTH1848XP Hydrostatic Rider that runs fairly well for about 15 - 20 minutes and then shuts off. Sometimes you can choke it long enough to drive back to garage.
Check the fuel cap, Loosen the cap off and try it, the fuel cap may be plugged or missing pieces. If no air is getting into the tank it will eventually stop the fuel flow to the carburetor and if it sits for awhile you may be able to start it again for another 15 - 20 minutes. It will be worse with a full tank of fuel.
Jun 12, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Craftsman DLT 3000 with 18.5 OHV Briggs and Stratton engine. Have a brand new battery, It cranks, but does not start. If I jump it from a car, it starts and runs for as long as needed.Does not...
Can you check your battery voltage?
Is the car voltage higher than the mower voltage?
If you can jump it, it would seem that it should start with any equivalent battery.
Gary
May 08, 2011 | Garden
I have a Craftsman 917.272751 riding mower. While cutting the grass I shifted my weight and it popped but everything still worked fine. However, about an hour later it popped once again and this time...
Check your seat safety switch under the seat there is a switch so if you get off the mower it will shut off and not start,it wont even let the oven crank. Check that switch you can get a new switch but first check the switch out with a continuity meter to make sure it works. When you push the switch in you should have a closed contact the meter would let you know by sound or by visible numbers. To further check to see if the switch is bad you can by pass the switch by using a paper clip in the switch socket on the seat. if all is normal again then get a new switch.Make sure you remove this clip and buy a new switch as this is a safty switch which has to be installed.
May 02, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman rider wont stay running
Once having the same problem with the B&S engine, I had to replace the ignition coil. When it is in the process of failing, it acted as you describe.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
278 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
