Question about Refrigerators
Refrig door stays open
The door on my MTB2148DR Maytag refrigerator no longer closes automatically. It often stays open just a crack unless given an extra push. How can I adjust it?
  • 725 Answers
Your refrig has legs you can adjust down ... this will tilt the refrig to the back so it will close be itshelf...
hope it helps let me know if it helps
Posted on Sep 26, 2009
I have a Magic Chef refrigerator Model GT17A7V, Serial 11993269QS. It does have wheels, but we needed to adjust the wheels in order to make it easier to roll. Problem: The refrig & freezer doors now...
Unfortunately, when you adjusted the wheels to be able to roll it easier, you thru off the tilt required for your doors to swing the way they should.
You are going to have to adjust them again, to have a front (high) to back (low) tilt. If you have a right hinged model it should be adjusted very slightly higher than the left.
Aug 15, 2011 | Maytag Refrigerators
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Right door will not stay closed
Put vaseline on door seals
May 26, 2009 | Maytag MSD2758GEW
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Soap dispenser
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Jun 04, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
On electronic control panel and water/ice despensor the ice cube door keeps opening and closing and the buttons on the panel do not respond tempratures of fridg and freezer keep flashing. Tried unplugging...
you have a maytag ice and water in door 3 door refrig???? if so you needs a new high voltage board, its gone bad. locatdon back wall behind the refrig. only resolution is to replace the board..
Mar 16, 2008 | Refrigerators
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
