Question about Garden
Won't start, replaced spark plug and air filter
I have a lawn boy lawn mower 4 cycle engine serial number is 260020568 and it run fine one day and went to use it again an it won't start, replaced spark plug and air filter just doesn't fire .
Also could be a bad ground. Quick way to check remove top cover and shroud. Remove 2 slip connectors (ground wires) going to coil. Put it all back and try to start. If it starts it's the ground. If it doesn't try replacing the coil as discussed above. If it does start, replace each ground one at a time if it does not start, you know that ground is bad. Retry, same procedure with other ground by itself. If it does not start then it also is bad. Trace the ground wires and rerun or test and splice. You can also run the mower with out the ground, but they serve as kill and safety switches so I do not recommend this.
If you have a bag sensor you can easily check it with a meter. Located on top right corner of my mower. Bag bar rests on it. Cut the 2 wires 1/2 way from the sensor, put a mutlimeter to measure the resistance when there is no bag it should read 0 ( the switch is closed). Place the bag on, retest, if it is working it should now read closed, this keeps the mower from runnning without a bag
Posted on Apr 03, 2011
  • 437 Answers
One of two problems, ignition module has gone bad or carburetor needs rebuilding. I would replace the ignition module first. If you have the model, type and code of the B&S engine, you can go to www.precisionope.com and look at the IPL for the part number you need.
Posted on Sep 26, 2009
Lawnboy model 10415 serial number 5901752 correct spark plug
Joe, Factory Lawn Boy SPARK PLUG 614009, replacement plugs champion CJ14, NGK plug # BMR4A.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Boy 10415 Lawn Boy Gold Series Walk Behind Mower 1995 SN 5900001...
614009 Spark Plug
Which spark plug for Lawnboy engine
https://www.shoplawnboy.com/Comergent/en/US/adirect/Toro?cmd=ToroLBOnlineModelLookup
Aug 04, 2016 | Garden
Mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Jun 16, 2012 | Toro Power Lawn Mower
Troy built mower honda 160 engine oil leak around governer shaft. no oil seal but shows one on parts breakdown. Can not find part number for shown seal.
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
May 24, 2012 | Troy Garden
Lawn Boy mower will not start. New gas and plug.
Is the plug getting wet? if not, try introducing fuel to the intake and attempt to start it again, the interlock on the handle works by killing the ignition fire and applying a brake to the flywheel, this should be a Tecumseh engine, carb troubles are quite prevalent on these, by substituting fuel to the intake you are acting as the fuel supply, if it starts and runs briefly you have confirmed a fuel system issue
Jun 01, 2010 | Garden
Lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
May 29, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
What is the spark plug gap setting for a LAWN BOY DURA FORCE engine 2-cycle 6.5HP?
from what I have seen so far the gap is .30 for all manual start 2 cycle and 4 cycle and .35 for electric start
Mar 11, 2010 | RTO Lawn Boy 6.75hp Mower
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
228 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
