Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
MOTOR STARTS, SPUTTERS THEN DIES - Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
  • 437 Answers
Carburetor clogged up, air filter clogged, spark plug fouled; old gas.
This is the best suggestion I can come up with on the information you gave.
Posted on Sep 26, 2009
My car is sputtering and dying. If I try to restart it, it will immediately go into sputtering/dying mode. If I wait a while an hour or so it will start up and drive fine.
When was the last time that the carburetor was stripped and cleaned? Also have you checked the fuel filter? Finally, the problem seems to come and go as the engine is run (and it gets hot) check that the fuel line and any electrical cables are well away from the hot engine as far as is possible.
Jun 16, 2015 | Cars & Trucks
Ford truck idles fine but sputters and dies when gas is increased
I have a 1989ford econoline motor home I live in Victoria Australia the problem I have is that it runs on gas and petrol there is a part that fits on air hoses from carnie to air cleaner it looks like a set of burn oculars 2hoses fit in one endadnd 2hoses at the other end we can not find the part any where in Australia
Feb 17, 2012 | Ford Econoline Cars & Trucks
Starts cold but sputters and dies when hot
It sounds like it is getting too much fuel. check your fuel sensor. Your choke is sticking open. Buy some carb cleaner. Remove your air filter and spray the linkage to clean it up. Make sure it moves easy. Start your car up. the butter fly on top of the carb will be closed all the way. As the motor warms up this should open up gradually. If it doesn't you have a problem with the choke system and it is not letting air in as the motor warms up.
Feb 14, 2012 | Chrysler LeBaron Cars & Trucks
Van sputters on wet days and does not sputter when dry outside. When you come to a complete stop (when it sputters) the van will die.
Not really much detail about what kind of vehicle you have or what motor But it sounds like you have condesation in the cap or the ignition wires are holding moisture. Start by replacing the distributer cap and rotor if this does not solve it then replace the ignition wires and this should solve your problem cap & rotor around $60 and wires are around $100
Apr 26, 2011 | Chevrolet C3500 Cars & Trucks
My saw will start but dies immediatly
Spark plug gap The right spark plug and the right gap is critcal to good running on a 2 cycle motor(you DO have gas in it right?)
Aug 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Sputters then dies
Most likely a lack of fuel, check the fuel filter first.
Aug 13, 2009 | 1988 Saab 900
1987 cutlas ciera 3.3 v6, sputters and idle poorly before dying
locate the ECM under the dash on the right side in the side kick panel, gain access.do not remove it,light tap on it while it runs see it the motor changes.you probably need another ECM.I would have to have more info to help you better.
Jul 23, 2009 | 1987 Oldsmobile Ciera
Battery
Usually, if the battery is dying, it won't start up again.
Usually, motorized vehicles only use the battery to start the engine, then the alternator contributes all the power for actual operation.
A dead alternator or battery shouldn't 'sputter', they would just stop dead.
If the engine will start, run and then sputter...there is a fuel problem.
1. There may be a 'cut-off' in the fuel line which is in the off postion. It may look like a thin, flat wing-nut.
2. The gas may be contaminated with water residue if the gasoline has been sitting a long time. I believe you can get some water treatment to fix this without having to dump the fuel tank contents.
3. The fuel line is blocked with dirt somewhere, I would check the fuel filter and work backwards from there.
Jul 07, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a 95 firebird formula LT1 that will sputter and want to die. This will only happen if I drive for about 30 minutes then stop and shut off the car for 15 minutes. Once I start it after that it bogs...
map censor... manafold absolute pressure censor.. the mecanics have a hard time finding this censor it is secondary to the motor circuts but it will cause the motor to die then restart in a short time...$30.00 autozone
Jul 07, 2009 | Pontiac Firebird Cars & Trucks
Engine sputtered, then died. Towed home. I
Might be fuel pump, or filter is pluged up, best to chg. filter and then do a fuel pressure test.
May 03, 2009 | 1994 GMC Sierra
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
556 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
