Question about HP Photosmart 2710 All-In-One InkJet Printer
Changed ink cartridge on HP Photosmart 2710. Cover is "UP". Where is button to get cover latch to release and come down?
  • 106 Answers
SOURCE: Keeps stating ink expired
i guess your printer has reach the printing warranty.. try to search in the web on how to reset your printer, ^^
Posted on Feb 16, 2009
  • 23 Answers
SOURCE: How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Posted on Feb 17, 2009
  • 84 Answers
SOURCE: Ink System Failure on a HP Photosmart C6280 All-in One
This is likely a cartridge problem except if the carriage is not moving at all. If you still have some of the used cartridges you can used them to trouble shoot by elimination ok. Or contact a nearby technician who has the cartriges to use them for trouble shooting. I strongly believe the one of the print carts is the culprit. Good luck
Posted on Jun 02, 2009
smwsolutions
  • 73 Answers
SOURCE: printing error oxc18a0101
Try resetting the printer:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on.
Posted on Jul 19, 2009
SOURCE: i changed my ink cartridge, but the top cover
Lift the printer cover. There is a slot on the right side by the ink cartridges. Push the end of your little finger into the slot. Close the lid. I know this sounds lame, but it has helped me many times. It seems the latch will stick and this usually unsticks it.
Posted on Oct 08, 2009
HP Photosmart 5180 has ink cartridge problem, Says following ink cartridges appear to be missing or damaged.
Solution
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.NOTE:The printer will not operate unless all six ink cartridges are installed Step one: Reset the printer Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.Without turning the power off, remove the power cord from the back of the printer and from the wall socket.Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.Check the printer for the error message. If the error message still displays, go to the next step.Step two: Clean the cartridge contacts Lift the top cover. Figure 1: Lifting the top cover Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch.Figure 2: Unlatching the cartridge 1 Black cartridge 2 - Color cartridges Remove the cartridge indicated in the error message.Figure 3: Removing the cartridge Gather the following cleaning materials:Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.Lightly moisten the swab or cloth and squeeze out the excess moisture.Holding the cartridge by its handle, wipe the copper contacts.Figure 4: Wiping the contacts 1 - Copper contacts Replace the cartridge and then close the latch and the printer top cover.Check the printer for the error message. If the error message still displays, go to the next step.he printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge.
Oct 04, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have a HP k8600 printer. I changed the black ink cartridge and now it won't print any black, only other colors. What is the solution?
Here are some steps that can help you resolve yoour issue.
Make sure that we use a genuine HP ink cartridge
Try printing a diagnostic page from the control panel. Here are the steps:
Press and hold the Power button
Press the Cancel button for seven times
Press the Resume button for 2 times
Release the Power button
If the issue persist
Try Cleaning the printheads. Here are the steps:
Make sure there's unused paper
Press the Cancel button 2 times
Press the Resume button 1 time
If still the problem persist try reseating the cartridge
Open the cover
Make sure paper is loaded in the Tray
If the carriage does not move to the left automatically, press and hold the Resume button until the carriage moves to the left. Wait for the carriage to stop moving.
Lift the printhead latch
Lift the handle of a printhead, and use it to pull the printhead out of its slot
Before installing a new printhead, shake the printhead up and down at least six times while the printhead is still in its packaging.
Remove the new printhead from its package, and then remove its orange protective caps, Do not shake printheads after the caps are removed
Insert the printhead into its color-coded slot. Press down firmly on the printhead to ensure proper contact
Pull the printhead latch all the way forward, and then press down to ensure that the latch is properly engaged. You might have to apply some pressure to engage the latch.
Close the cover, wait while the device initializes the printheads and prints the alignment pages
If the problem persiste contact HP support for service.
I hope this will help you resolve the issue.
Thank you for choosing Fixya
Mar 10, 2011 | HP OfficeJet Pro K8600 Printer
The display says "ink system failure", can't
You will need to disconnect the USB cable and then disconnect the power cord. Now open the cover and take out all print cartridges. Next, close the cover and reconnect your power cord (if printer does not come on automatically, press the power button) Now just open cover and insert your ink cartridges. Make sure the ink cartridges have ink in them and they are not empty.
Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP 339 ink cartridge is not supported
Hello
For HP 2710, you need HP 96 and 97 number ink cartridge, 339 is not compatible with this printer.
Hope this helps
Jan 28, 2011 | HP Photosmart 2710 All-In-One InkJet...
How to change the ink cartriges
With the printer turned on, open the top cover (just lift up). Squeeze the gray tab below the ink cartridge to be replaced and lift up. Pull the old cartridge towards you. Unwrap the new cartridge and slide it into the slot with the copper contacts facing the printer. Press down the grey latch until it clicks. Repeat this for all empty cartridges. Close the top cover.
For pictures: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00387004&lc=en&dlc=en&cc=us&product=443024 .
I hope this helps.
Jan 02, 2011 | HP - HP Photosmart 8250 printer
I was installing the yellow ink and then all the sudden after I installed it the message Error Oxc18a0301 appeared! How do I fix this?
Shut down your printer by pressing Simultaneously Cancel + OK + Black + Color.
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or re manufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
  1. Lift the top cover. Figure 1: Lifting the top cover
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts (1) - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Nov 24, 2010 | HP Photosmart C6280 Printer
Installed new cartridge, still displays empty
Hp Cartridge issue
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
Figure 2: Unlatching cartridge
1 - Black cartridge
  1. Remove the cartridge indicated in the error message.
Figure 3: Removing cartridge
  1. Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
  2. Lightly moisten the swab and squeeze out excess moisture.
  3. Holding the cartridge by its handle, wipe the copper contacts.
1 - Copper contacts
  1. Replace the cartridge, then close the latch and the printer top cover.
Apr 22, 2010 | HP Photosmart 3210 All-In-One InkJet...
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
I cant get the cartridges into my hp photosmart 2710. I know I have the right cartridge but it wont fit in!
First is the printer on? Once the access door is up, you need to push down them up on the cartridge latch. Next, make sure the label is up and the copper colored contacts are facing into the printer. Bring the cartridge down to the right height and push forward until it stops. Then close the latches and then the access door.
The black ink goes in on the right and the color to the left. They are not identical.
The usual difficulty is not pushing the cartridge in far enough. It really won't break easily.
I hope this helps.
Sep 13, 2009 | HP Photosmart 2710 All-In-One InkJet...
Printhead problem (black/yellow) on HP L7780
When you removed the paper it's possible your damaged it and that's why the message is not going away. Did you try to put the cartridge back in to make sure it had not come out of position and just remove the power cord for a minute then plugging it back it.
Here are the steps to make sure you properly change the cartridges and the heads...
Install the ink cartridges and printheads Step one: Install the ink cartridges All four ink cartridges must be correctly installed for the HP All-in-One to work. Follow the steps below to Install cartridges:
  1. Open the ink cartridge cover.
  2. Remove each ink cartridge from its package.
  3. Align each ink cartridge with its color-coded slot and then insert the ink cartridge into the slot. To ensure proper contact, press down firmly on the cartridges until they snap into place.
  4. Close the ink cartridge cover.
Figure 1: Installing cartridges c00841893.gif 1 - Open the ink cartridge cover. 2 - Remove the ink cartridges from the packages. 3 - Install the ink cartridges. 4 - Close the ink cartridge cover. Step two: Install the printheads Follow the steps below to install the printheads.
  1. Open the top cover of the printer. Figure 2: Open the top cover c00848391.gif
  2. If the carriage does not move to the left automatically, press and hold the Resume button (c00847980.gif ) for three seconds. Wait for the carriage to stop moving.
  3. Remove the cardboard cover from the printhead carriage. Figure 3: Remove the cardboard cover c00848392.gif
  4. Lift the printhead latch. Figure 4: Lift the printhead latch c00848393.gif
  5. Before installing a printhead, shake the printhead up and down at least six times while the printhead is still in its packaging. Figure 5: Shake the printhead while it is still in its packaging c00847983.gif
  6. Remove the new printhead from its package, and then remove its orange protective caps. CAUTION: Do not shake printheads after the caps are removed. Figure 6: Remove the printhead from its packaging, then remove the orange caps from the printhead c00847984.gif
  7. Insert the printhead into its color-coded slot. The label on the printhead must match the label on the printhead latch. Press down firmly on the printhead to ensure proper contact. Figure 7: Insert the printheads in the correct color-coded slots c00847985.gif
  8. Pull the printhead latch all the way forward, and then press down to ensure that the latch is properly engaged. You might have to apply some pressure to engage the latch. Figure 8: Close the latch c00848394.gif
  9. Close the top cover. Figure 9: Close the top cover c00847987.gif
Step three: Align the print heads Whenever you insert or replace a printhead, the printer automatically aligns the printheads to ensure the best print quality. If the printer does not print the alignment page automatically, start the alignment process manually. To start the alignment process manually:
  1. Press the Setup button on the control panel Setup and the number 6 on the keypad or scroll to Tools .
  2. Press 4 on the keypad or scroll to Align Printer . The alignment process starts.
Dec 01, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Photosmart 2710 All-In-One InkJet Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
