Question about Garden
I have a craftsman chainsaw model no. 358356081 that idles fine but bogs down when you pull the trigger. I checked the fuel line and noticed there are 2 lines coming from the tank. The one to the carb is ok but there is another that fell off. What does it go to?
    President:
  • 2,220 Answers
Does it have a fuel primer bulb?
Posted on Sep 26, 2009
I have the same saw and the same problem. The other line seems to be a breather line. It looks like it has some sort of filter plug in the end. Seems it just needs to point up. I wonder if the problem is that ours is not breathing properly. Goin' to check.
Posted on Jul 08, 2010
What is the spark plug gap for a Sears and Roebuck chainsaw Model # 358.356081
The spark plug gap must be 0.025". This is given in the manual on page 18.
SearsPartsDirect.com has the manual for the Craftsman 358.356081 chain saw here: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/user-manuals/manual-downloads/Model-358356081/0247/1503220?modelNumber=358356081&diagramPageId=&documentId= . The direct link to the manual is http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0807005.pdf .
I hope this helps.
Dec 24, 2015 | Garden
Keeping me up at night!!
It sounds like something got switched in the reassembly. It happens. Here is the service manual to try and figure it out. Let me know if that helps, or you need some more help. Good luck.
Service Manual McCulloch MS1432
May 14, 2014 | McCulloch Ms1432, 14" Chainsaw Chain 49dl...
Won't idle and when trigger is fully engaged it bogs out?
This could be several things..fuel filter in tank clogged, hole in fuel line, clogged carb., hole in carb. diaphram or leaking crank shaft seal under flywheel or chain sprocket,,,engine block acts as fuel pump..hope this helps
Jul 25, 2012 | Craftsman 38cc 16 In. Gas Chain Saw
Craftsman chainsaw has no power
I would first check your muffler and screen in muffler to make sure it's not partially plugged. Personally I think it sounds like a fuel delivery problem,I would make sure you change your Fuel filter and check your lines for being cracked and or collapsing from ethonal in gas these days. then I would put fresh gas in it and see if it helps.you also need to clean carb and then readjusr carb after cleaning carb
Jan 02, 2012 | Garden
The saw stalls when under load and at high speed, runs good at idle and mid speeds, when you pull throttle all the way back with out load saw will bog down and die.
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor is solidly mounted to the engine. Hope this helps!
Dec 05, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I can start my line trimmer and t idles fine but when I try to accelerate the motor ( pull the trigger , the engine stops. Can you shed so light on what may be wrong? Ian
have you checked for blocked muffler screen or exhuast port/ muffler
2 stroke wil idle sometimes with blocked/ restricted ex port / muffler
then just go burrrrr if try to pull more revs
no exhaust out , no fuel mixture gets in basically not breathing
have you checked fuel filter and fuel lines ?
tried new plug?
try blocked ex port and muffler 1st
cheers
Aug 08, 2010 | Garden
Idle is off??
hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Nov 22, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
187 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
