Question about Creative Labs Gigaworks S750 Computer Speakers
Subwoofer crakling sound when playing anything.
Here's the deal. Everything powers up, but when i raise the volume, the sub start producing a cracking sound and if a raise the volume real hi the sub just died. Also one of my rear speakers doesn't work.
  • 1 more comment
  • Ronaldlora Dec 18, 2007
    First of all thanks for the Inputs.
    Hey you don't happen to know which resistor it is, i'm pretty good with electronics, and i want to see if i can repalce it myself. Now is Creative doing anything about this? Like product recall or at least free repair? I wouldn't even consider getting a new creative system, if this is what they call top of the line, imagine the rest, my system has being more broken than good. If i can't get this fix, i might go the Bose route. Is like a friend says Plug and Play. Do you know any shop that makes these repair, like Circuit City, or Best Buy.
    Again Thanks,
    Again Thanks,
  • Ronaldlora Jan 10, 2008
    Thanks for your inputs. The thing is that the crackling sound comes from the SUB not the Speakers
There are 2 possibalites
1) sound system does might not be supporting the volume that you want
2) The speaker coil might have become weak so it might be making cracking sound
Posted on Dec 18, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello Ronaldlora
Happy Holidays
Hi, this is a particular problem for this speakers, and subwofer, it is a resistor inside the sub, you have to fix it in a repair shop, or ...sadly, change for another model of Creative Speakers, for example one good one is the 7800 Spk. good ones.
but like I say is a problem that creative labs is aware too.
  • Carlos L. Burgos
    Carlos L. Burgos Dec 18, 2007
    Ronaldlora
    hi again!
    Well, I don't really remember the name of this resistor, but Creative know, that some models, and the board, has this problem. your , depending on your warranty, can RMS the speaker or SUB, for a repair or change. But, you also fix it.
    I don't really know there if has a good repair shop, but try it.
    good Luck
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
Help me please i have problems with my sistem x-530 logitech!!! i need to change the fusel i dont know
The speaker is designed for computer and not designed for playing at loud volume. Sound like you have blown a fuse, check the fuse on the back of the subwoofer and replace it with the same rating fuse. The speaker are only rated at 2 to 20 watts max, with the sub at full volume it did not have the power required to produce the sound thus blowing a fuse or burned out. The bass is the most power hungry of all the frequency, if you are using 5 watts and the note spikes to double your amp has to have 50 watts of power to produce the sound. Hopefully it was only the fuse, good luck.
Mar 14, 2011 | Computers & Internet
My subwoofer output is not working properly. I have a sunfire signature that worked all the time. Now the power on the Sunfire will not come. Research says no signal from receiver. I swithed the...
You can prove the sub pre-output works by running an RCA cable from it to the input of a tape deck, TV or any other device that accepts Line In and will either display it or play it. Test it on VERY LOW volume at the receiving device.
Different sub pre-out cable?
Feb 11, 2011 | Denon AVR-4800 Receiver
I have a Kenwood VR-507 surround system. Everything works great except the subwoofer. I am trying to determine if the problem is the speaker or the receiver. No sound comes out , not even during setup. It...
You need to determine if its the sub or the amp.
Dive back into the setup and make sure you have the sub defined (page 19). Run setup. It should work.
If not, tune FM, run an RCA cable from either Record Out channel to the sub's input; or connect a CD directly to the sub. Gradually raise the volume with something bass-rich playing. That ought to wake it up. If not, the sub is dead.
Feb 03, 2011 | Audio Players & Recorders
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Aug 04, 2009 | JBL GTO14001 Car Amp
When volume turned up subs pop then immediatly produce no sound
u might have to turned your amp so u can play both subs your amp might be to small to run both subs at the same time an u gotta play around with the settings on your cd player so when u blasted your subs it has that nice bass to it not that poping sound.
Apr 04, 2009 | Jl Audio 13W7 Car Subwoofer
Stops working
THEY MIGHT BE DRAWING MORE CURRENT THEN UR ALTERNATOR CAN HANDLE.TRY CONNECTING A CAPACITOR FOR THE SUBS.
Feb 01, 2008 | Bazooka EL1204 Car Subwoofer
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Dec 28, 2007 | Onkyo HT-SR800 System
Creative Labs Gigaworks S750 Computer Speakers Logo
219 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
