Question about Canon PowerShot S500 IXUS 500 Digital Camera
My batteries are full but camera won't switch on, it's dead!!!
I tried to switch camera on today which as normal came on managed to get a couple of pics but then went dead recharged all 3 of my batteries but camera seems dead with all 3!! Just won't power up!!
    President:
  • 2,761 Answers
Your problem may be due to worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
  • Canon Master
  • 4,738 Answers
It might be a problem with one of the switches at either the battery or flash card door.
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try.
Posted on Sep 26, 2009
Camera won't turn on
check the age of the batteries bc my rechargeable ones only lasted 4 years and they wouldnt even hold a charge for a couple of pics
Aug 15, 2012 | Panasonic Lumix DMC-FP3 Digital Camera
Camera was low on battery. Took a couple of pictures with no problem then got it home to charge the battery and the camera is dead. Won't turn on or charge. Tried plugging it in directly with the...
1. Check if the battery is positioned and seated well in the camera.
2. If OK, and problems persists, exchange the battery and recheck.
3. If that does not help, your camera needs probably to be repaired.
Aug 05, 2011 | Olympus SP800UZ Digital Camera
My Kodak EasyShare C180 10.2MP Digital Camera is less than a year old and suddenly won't turn on. I thought the batteries were dead so I replaced them...twice...and tried changing the direction around...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 06, 2011 | Kodak EasyShare C180 Digital Camera
Won't switch on. Was working fine; battery running low so removed it to recharge as I have done many times before. On reinstalling battery the camera is completely dead.
Jun 28, 2011 | Pentax Optio A30 Digital Camera
I got the kodak easy share 143 model camera coming brand new off of ebay yesterday,,,but it keeps saying my batteries are half drained, then dead after a couple of photos. Then if they're dead it...
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 26, 2011 | Kodak Cameras
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
I don't use my camera very often but when ever i do, it seems like it is always dead. a couple days ago i plugged it in to download some pictures to the computer and it was at full battery. i forgot about...
I don't expect something wrong other then the battery is totally flat, just take the battery out of the charger unplug the charger wait a few minutes and plug the charger back in and insert the battery again. I've had to do this upwards to three times before the battery and charger got the idea what they were suppose to do. Rechargeable batteries normally don't like long periods between use and when they do loose their charge it can be down right annoying getting them back into service.
You didn't say what camera make or model or if the camera uses a designated battery or AA's.
Jan 21, 2011 | Cameras
Battery?
i just got mine today, and the batteries were dead withtin a couple of hours, so yes. mines has decided to go black, it was fun while it lasted,, theres £90 ill never see again
Aug 24, 2006 | Samsung Digimax S500 Digital Camera
Canon PowerShot S500 IXUS 500 Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
