Question about Samsung Omnia Pro B7320 Smartphone
When charger is plug in, battery icon changes to ac icon. There is no indication when battery is fully charged. How do i know when should i switch off the charger?
On the top the red light is glow which means battery is charging when full charge it becomes green
Posted on Oct 19, 2009
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Just want to know what the code FLO stands for kid lost the manual
The digital display shows "FLO" to indicate that the unit is in float charge mode. The battery "fully charged" icon will display on the LCD screen and the arrows pointing to the "+" and "-" will flash. In this mode, the unit monitors the battery voltage and charges as necessary to assure the battery maintains full capacity. The unit remains in float charge mode as long as the charger is connected to the battery and plugged into a functioning AC outlet. I hope this has answered your question.
Apr 01, 2011 | Stanley Black & Decker Stanley Bc1509 15...
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
New battery in eMachine M6811 won't fully charge.
1) Control Panel / Security & Maintenance / Recovery
Feb 22, 2018 | E-Machines M6811 Notebook
Just bought a second hand acer travelmate 4200. I have never owned a lap top. How do I change from using battery power to outlet power
On the left side, towards the rear is a DC jack. Plug the power cord in there. It should automatically start operating on AC power, and charge the battery.
Feb 24, 2010 | Acer TravelMate 4200 Notebook
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
How do I know that the GPS is charging. The light is green when pluged in. Should it not be red then go green Lorraine
On a Nuvi 200W, when you plug in the charger, the battery status icon should go away indicating that you are no longer on battery power and that you are now running on an external power source. You should also hear a beep when you plug in the charger.
To go into charge mode, move the on/off switch to the left like you would be going to turn it off but only hold it on long enough until you hear it beep or the screen goes black and says "Battery Charging". When the battery is fully charged, touching the screen, it should say "Battery Charge Complete". If its not fully charged, touching the screen, it will say that it's still in charge mode.
- Jim
SHARCNET-USA
Feb 25, 2009 | Garmin nuvi 200W GPS
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Samsung Omnia Pro B7320 Smartphone Logo
326 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
