Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Saw a ''Wild THing'' starts but as soon as you attemo to cut even small branches it stops immediately. It will restart but same problem continues Carb jets appear clean and clean fuel is used. I also want to know the nearest Repair service covering the area code 01826
  • 148 Answers
Check the screen inside the carb directly under the inlet neelde. These commonly swell and restrict fuel flow. If you cant see light thru it you arent getting adequate fuel flow. Also check fuel hoses for tiny pin-hole leaks at the points where the hose makes a bend or turn. Adjusting the fuel/air mixture screws may not be possible on newer machines, but if yours are, richen them SLIGHTLY and check for better throttle response.
Posted on Sep 26, 2009
    President:
  • 2,220 Answers
Service locator for your saw can be found here:
http://www.poulanpro.com/node4042.aspx
HTH
Lou
Posted on Sep 28, 2009
How can you buy just the saw for the 8" 2 in 1 pole saw.
after looking at reviews written on
http://www.chainsawsdirect.com/Earthwise-CVPS41008-Chain-Saw/p7224.html
Robert
Tried chain saw. Working on limbs about 12 ft above ground.
First limb about 3 inches diameter, Oak. Worked fine.
Second limb same size. Cutter slip off branch could not stop the saw from hitting ground. Broke case where it attaches to pole.
No parts, and no way to repair it as company had no idea what kind of cement/glue I could use. So one branch cost me $120.00.
Sent To Customer Service
Shawn
Like Robert my saw hit the ground and busted in the same spot (this will happen to you sooner or later) and you can not get repair parts, its now a door stop.
Pros: Easy To Use, Light Weight
Cons: Can Not Get Repair Parts
I am guessing you mean the entire cutting end of the saw too, I would get a new one either same model so you have a spare pole or find a another brand that definatly sells spare parts.
Ive never used a electric polesaw but have done alot of work with with longer petrol and shorter hydrolic polesaws, even top of the range they can be broken easily always keep the chain sharp, cut one branch at a time or small clumps on a hedge.
Commonly they get dropped cause they get really heavy extended a shoulder belt helps alot as do coffee breaks.
Or they get jammed in the branch being cut which can be really dangerous with a half cut branch, be ready to run.
Also never use from a ladder
Jul 07, 2014 | Earthwise CVPS41008 - 8" 6.5-Amp Electric...
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan wild thing chainsaw has 3 tuning screwes h,l,t and they have all been messed up how many turns out do they all need to be from all the way in
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. T is the idle speed screw and not critical--just back off about two turns CCW at first. Turn H and L jet screws CCW from stops 1-1/2 turns each--this should allow the engine to start and run. Start the engine and allow to warm up--if the idle speed is too high or low, adjust the speed screw so that the engine continues to run, but the chain is not trying to turn. When warmed up, pull the throttle full on and adjust H needle CW until the engine starts to speed up. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L jet screw CW until the engine idles fairly well, but still allows the engine to 'follow the throttle'. If adjusted too far, the engine will 'gasp' when throttled. Set the idle speed screw to obtain the above conditions. Hope this helps!
Jan 22, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
When cutting wood saw will not oil chain whats the problem
make sure oiler jet under the chain tightener plate is clean even take bar and chain off and start saw
Dec 12, 2010 | Poulan 18" Wild Thing Chainsaw
My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The chain slows down or stops when cutting. The engine runs fine and doesn not slow down. I checked the oil, cleared the oil vents to the chain, the brake is fine and is not causing the problem. The...
THE SAW IS RUNNING FINE . WHEN THE CHAIN STOPS AND THE ENGINE IS STILL RUNNING AT HI THROTTLE THE CLUTCH MAY BE WORN AND SLIPPING. PULL THE CHAIN AND BAR AND SEE IF THE CLUTCH HOUSING IS BLUEISH IN COLOR IF SO I WOULD REPLACE THE CLUTCH
Sep 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Runs about 10 minutes 7 cuts off. can't restart
Plan your beer breaks every 10 minutes and enjoy the time off. Also check your fuel mix, the engine is running hot, replace fuel mixture with proper oil mix.
Jul 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wont stay running when you let off the gas???
Sound like the carb was never adjusted right. Unfortuatley, the carb adjustment screws require a certain tool that's not available to the public. (EPA thing) You'll have to take it to a shop to get it adjusted. That should solve the problem.
May 25, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
181 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
