Question about Dryers
Thermostat? creda dryer thermostat change , 2 thermostat look the same,for hott and cold ,cant see any diffrent ,is there any diffrent?
  • hansvil Sep 26, 2009
    Thank you ,i will change bouth of them!
  • Dryers Master
  • 5,138 Answers
NO,I there shouldnt be any if you have another one try itand see if it works. And are you sure the other one is Good? I would ssume If it is a dryer thermostat they would draw same amount of current.
Posted on Sep 26, 2009
How do i fix a tumble dryer blowing cold air
When you have to put this question here, I don't think it is wise to try to repair it yourself. It can be caused by lots of different things, Like a defective heater, a lose connection or a defect thermostat. When your dryer does not have an overheating security switch that came out and you can't reset it, a skilled technician should see into the dryer. It works with voltages, to dangerous to work with, when you don't know what you are doing. Please be careful.
Jan 30, 2015 | Indesit Ariston Creda Hotpoint Tumble...
Creda dryer kicks out breaker
could be one of the thermostats thats at fault, ,,
Sep 09, 2013 | Creda IWD12 Front Load Washer / Dryer
How to fit creda thermostats
It depends on which make and model of tumble dryer you have as to how easy it is to replace the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious burning out or open circuit. Others though have their heating elements inside, which aren't accessible without stripping the dryer down we will try and cover as many as possible in or video tutorials section. Tumble dryer heating elements are always protected by thermal fuses and thermostats which are usually simple devices with 2 wires connected and have a bimetal strip inside them. They can be tested for continuity with a test meter.
The problem is that if a stat (thermostat) or t.o.c. (thermal overload cut-out) has gone open circuit, it may be for a reason. Overheating could have caused it by not being able to vent the air due to a blockage some ware. Blocked filters or even the machine not being allowed its ten minute cooling down period, Overloading can cause it as well. Sometimes they can go for no apparent reason. A blocked or severely kinked vent hosecan also cause overheating.
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Jan 02, 2010 | Dryers
My creda tunble dryer model 37324 is working but
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 17, 2009 | Dryers
Creda dryer thermostat failed
you have an air flow problem
Aug 17, 2009 | Dryers
Creda debonair spin dryer lid not opening.
The lid had been fixed for delivery.Now it is opening OK thanks.
May 01, 2009 | Washing Machines
No heat in tumble dryer
Is this a gas dryer, if so check the thermal fuse, should be white plastic with 2 wire ports. These tend to bad first. Thanks Dave www.washermd.com
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Creda T620CW condenser dryer
Recently bought condensor dryer which was working fine till the very cold weather came. Is situated in the garage so temp has been going well below freezing some nights. Now keeps switching off after a few minutes and empty water light flashes although resovoir has no water in it. Is this due ti pipes freezing?
Jul 26, 2008 | Dryers
Creda tumble dryer
thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Mar 17, 2008 | Dryers
Thermostat wiring diagram for creda t622cw
I assum there are four wires, you really cant get them wrong as they are all Neutral wires so it won't go of bang, it just may not heat as it should, I would connect them as you think it should and try them.
Dec 02, 2007 | Dryers
Dryers Logo
21 people viewed this question
Top Dryers Experts
