Question about Daewoo DVRS05 DVD Recorder/VCR
Unable to operate recorder at all.
Hello, desperately in need of technical help. Problem is simple - neither vcr or dvd (combi) will work (play tapes/discs). TV works great but when i switch the recorder on/insert tapes, it goes blank and a message comes up to re-scan for channels, but when i try, nothing happens. How do i select the video input source? Everything is connected properly (to my knowledge), time is set, but next to the time it says DVD and won't switch to vcr when i press the vcr button on the remote.
Yes, i'm a total technical numpty! Any advice much appreciated.
    President:
  • 1,015 Answers
When you are turning the recorder on it is blocking the signal for cable going to the TV. Your TV will need to be on channel 3 or 4 depending on what the dvd/vcr player channel output is set to. This is why your tv is asking you to re-scan. It is losing the video signal because the dvd/vcr is taking over. The reason why the vcr with the button on the remote is because the vcr button is changing the function of the buttons on the remote to vcr. Even though the dvd/vcr is one unit they still will act like two seperate components independent of each other. They have seperate power buttons and the dvd player part may need to be hooked up seperately with rca cables to work.
Posted on Sep 26, 2009
Why does dvd.vcr combi which has worked perfectly since purchase in july 09 now suddenly turn itself off when trying to play/record
If it's the vcr side causing the problem then it could be dirty heads and/or rollers. run a wet cleaner through and this might solve.
Mar 29, 2010 | Televison & Video
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Magnavox VCR/DVD recorder model ZV450mw8. VCR plays a tape for 6 seconds then shuts the whole unit down.
You will need a technical person to open the unit. This problem can be as simple as a dirty sensor, or bad tape drive parts, or burned out computer chip.
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
CANNOT SET UP MENU ON TOSHIBA TDS_RDXV$*
Young lad next door showed hubby how to set menu up . Then noticed only HDMI cable NO scart lead for VCR did that as well. Thanks for getting back .
Dec 07, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Unable to record vcr while dvd playing
are you trying to record the dvd or tv or cable channels let me know then i can help
Jan 08, 2008 | Televison & Video
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
I cannot watch my dvd's i taped on the philips on any other dvd player
YOU MUST FINALIZE THEM BEFORE YOU PLAY IN OTHER DECKS, CHECK YOUR MANUAL
ON FINALIZING THE DISK
Dec 17, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Daewoo DVRS05 DVD Recorder/VCR Logo
255 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
