Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
No Black ink somthing is wrong with prinhead - Kodak EASYSHARE 5300 All-In-One InkJet Printer
0xc18a0206 error
ink system prime failure- the printer is no klonger able to hold pressure in the ink tubes- suggest you replace ALL PRINTHEADS in one go ( the problem may lie in just one printhead or the tubes themselves
If the prinhead replacemnet doesnt wotk then a new set of ink tubes and heads will be needed- this costs about the same as three new c6180 printers and is not worth the money- sorry for thew bad news
Jan 20, 2014 | HP Photosmart C6180 All-In-One InkJet...
How do i fix a / clean unable -51 code on my MFC-240C printer ?
you cant clean
Inside the printer behind the cartridge carrier is an ink absorber. This devise is used to clean the excess ink from the prinheads after printing. THe unable to clean 50 is an indication that the absorber is full and needs to be replaced. It must be changed and cannot just be cleaned. You can order one from Brother and the instructions for replacing it are in the package with the new one. Until this is changed the printer will not operate.
Dec 23, 2013 | Brother MFC Office Equipment & Supplies
Hallo, Problems prinhead Canon MP980. After cleaning in the various ways via the cleanng programs of " Maintenance" the printhead on place of the black (the long one) is full of ink and does...
When you say the black ink was full again are you referring to the area around the black cartridge? If so it sounds as if the black ink is flowing much too quickly.
Some refill stations use very low grade, water based inks can have this effect.
The 520 Black (large one) is a pigment black, and should only be refilled with a true pigment black, and the small black is a photo dye black. if the station can be topped up I would try different Brands of black. If it can not there are refill methods out there that require only a 10ml syringe, large needle tip, 3-4mm hole maker and plug for this hole.
I hope this helps Regards GM
If this answer was useful please say so below by rating it. Thank You for supporting the FixYa Community
Apr 16, 2011 | Office Equipment & Supplies
Printer doesn't print black ink.
replace the black cartridge and clean /realign the cartridges and prinheads
Mar 26, 2011 | HP OfficeJet V40 All-In-One InkJet Printer
We have installed new inkjet cartridges for the inkjet 1200 printer, however there is no inkflow on the paper when printing documents. Please advise on what to do
Sounds like you need to replace the printheads. The business inkjet printers have seperate ink and prinheads. In home use printer models the printer cartridge is all in one with ink and printhead in one unit.
Oct 03, 2009 | HP Business InkJet 1200D Printer
Pink ink not coming out
This seems to be a common problem with Canon Pixma printers. Here is a web site with great info and instructions on how to cleand the nozzles on the prinhead:
http://www.inkjethelper.com/inkjetstuff3.html
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
"Banding" on Prints
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Aug 25, 2007 | Canon i9900 InkJet Photo Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
19 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
