Question about mares Scuba Diving & Snorkeling
I have a 6-window masres dive mask that has a broken part that holds the strap to side of mask. Any help?
  • 36 Answers
Most any dive store will have spare parts for your problem. Many masks have generic clips. Always carry some zip ties in you kit.
You can sip tie the ******** one or both sides in an "emergency".
Not as much adjustment that way though. ;' >
Posted on Aug 19, 2010
Where can I find a replacement strap for my scuba face mask?
Most straps are universal. But if you want an exact replacement just seach www.usdivers.com for your local US Divers retail store.
Sep 10, 2017 | U.S. Divers Scuba Diving & Snorkeling
How many time is normal mask life ?
it depends on the quality of the mask and it depends on how you stored it (if you leaved it at sunlight, if you washed it thoroughly after using it in the sea...)
i have a mid quality mask Mares mask, i have been using about 20 times for snorkeling, then i used it to take diving certifications in pool, then i used it for about other 20 dives in the sea... i always stored it in a dark bag (the mask is now about 8 years old)
you can check if you mask is still in good shape, and the silicone has not worn out, in this simple way: just put the mask on your face without straps.. remove all the air inside the mask by inhaling with your nose.. then look at your feet (keep inhaling): if the mask remains on your face you can keep using it
Apr 05, 2017 | Scuba Diving & Snorkeling
Can the mask strap that has for clips on each side, the strap and adjusters be purchased
Yes they can, you need to locate your nearest scuba shop that stocks Body Glove, they will be able to order them for you. Hope that helps.
Oct 24, 2010 | Body Glove Brilliant Recreational Diving...
Pin broke holding strap in place. replacement or substitution?
Standard repair part available at any USD SCUBA dealer. OR contact the company for a replacement part. Don't be such a brute in future.
Pulling hard on the strap adjustment will NOT make the mask fit better. It actually makes things worse.
Aug 13, 2010 | U.S. Divers Seal Diving Mask
Part that holds strap to the mask is broken.
It depends on the brand and model of Mask. Divers Direct sell some replacement buckles for Tusa masks. Tusa Liberator buckles and Tusa M10 buckles as well as a few for other models. Scubastore.com lists Mares Mask Buckles.
Probably the easiest is to go online to any of the major search engines and search for the brand name of your mask plus the words "mask buckles" and you should find a supplier (if there is one).
If not, you can try this fix. Not sure if it will work - kinda depends on what part of the mask buckle is broken. Good luck.
Jun 24, 2010 | U.S. Divers Cozumel Mask
I have an Akona Wahoo scuba mask and the strap has broken. Can I get a replacement?
Most any scuba shop will have replacement mask straps.
They are very common replacement.
Dec 01, 2009 | Akona Wahoo Junior Mask
The swivel part on the side where the strap connects to just broke. Is there a replace ment available? The plastic on the mask itself is undamaged.
Standard replacement part, sometimes generic. Go to any SCUBA store and ask for the part. In a pinch use a zip tie on the broken side as a temporary non-adjustable fix.
Aug 09, 2009 | Genesis Quadra Mask SM7400
How to choose a scuba mask
"The shape of the scuba mask and the silicone skirt on the mask must conform to the shape of your face to provide you with a comfortable fit. Ensuring the silicone skirt is a high-grade, flexible silicone can help to ensure the scuba mask conforms to the shape of your face and the long life of your scuba mask. Some people are allergic to different types of rubber, if you have an allergy to rubber, be sure to choose a silicone scuba mask because silicone is hypoallergenic. Always talk to your scuba diving gear retailer about the alternatives available to you. When trying on scuba masks you will notice the different shapes of the nose pockets. The nose pocket protects and cushions your nose, helps to keep your scuba mask from fogging during a dive and helps you to maintain equalization. Ensure the size and shape of your nose pocket is comfortable; not too tight and not too large. This will improve not only the comfort of your scuba mask, but your ability to purge your mask efficiently. There are increasingly different styles of scuba mask straps on the market. You may like the factory issue strap on your scuba mask or you may want to purchase a separate strap. Scuba mask straps are available in a single strap or a double strap design. The single strap should wrap around the centre of the back of your head. The benefit of the double strap is that you can position the top strap on the upper part of your head and the bottom strap on the lower part of your head to offer extra stability and comfort. Most scuba mask straps are rubber or silicone and fasten with a post-hole belt enclosure. Newer scuba masks offer a slide-lock type enclosure, which allows you to adjust the scuba mask quickly and easily when wearing the mask. Scuba masks are constantly improving. If you wear prescription glasses or contact lenses on a daily basis you can purchase a scuba mask without having to wear your glasses or contact lenses under your mask. Many manufacturers will create custom scuba masks which include your prescription in the front lens. A good sign you have chosen the right scuba mask for your face is when the mask stays on your face comfortably without using the straps to hold it in place. You should try this simple test with each scuba mask you try on for the first time: See our choices for scuba masks 1. Place the scuba mask over your eyes and mouth ensuring the mask is in the correct position. 2. Take a quick, light breath in through your nose and immediately start to breathe through your mouth as if you are scuba diving. This will create a slight suction between the scuba mask and your face. The scuba mask should stay on your face. If you must push the scuba mask against your face, or inhale repeatedly to help the mask stay on your face, the mask is not a good fit. 3. Keep the scuba mask on your face for approximately one minute. This will help you to determine how tight the seal is and how comfortable the mask is on your face. 4. Exhale gently through your nose to release the seal on your scuba mask and remove the mask from your face. There should be no mark on your face from the scuba mask. If there is a red line around your face from the seal of the mask, the seal was too tight or the mask is not the proper size for your face. Try the test a second time. If you still have a red mark on your face after you remove the mask, you need to continue your search for a scuba mask. Remember, a good scuba mask is one that's comfortable, doesn't leak and is easy to use."
Dec 01, 2008 | Vision Mares Pure Mask
Scuba mask maintenance
" 1. Use a defogging solution before every dive, even when diving more than once in the same day. This will prevent your scuba mask from fogging during a dive. You can purchase a commercially prepared defogging solution from any reputable scuba diving retailer. Squeeze a drop or two onto the inside lens of your mask and gently rub the solution around to cover the inside completely. Dip your mask briefly into water, swirl the water around the inside of your mask very quickly and empty the water from your mask. A quick rinse will remove any excess defogging solution from the inside of your mask. You do not want to get defogging solution in your eyes, especially while diving, since it can cause stinging and irritation. If you don't want to use a commercially prepared defogging solution you have a defogging solution readily available and it's free, your saliva. Your saliva will prevent your scuba mask from fogging just as well as any commercial defogging solution. The enzymes in your saliva stick to the lens of your mask like a commercial defogging solution and you will never find yourself without a defogger while on a dive. 2. Never lay your scuba mask face-down on any surface. Salt, sand and grit will scratch the lens of your mask. Always place your mask face up when you are not wearing it or if it is not in its hard case. 3. Rinse your scuba mask in clean, freshwater after each dive and dry it thoroughly before storing it in its hard case. After a dive, your mask will be covered in a salty residue and/or dirt. This must be rinsed clean to prevent the silicone on your mask from degrading. Your mask must be completely dry before storing it to ensure the silicone stays clean and odor-free. 4. Always store your scuba mask in its hard case. If your mask did not come with a hard case purchase an after-market hard case. This will protect your mask from dirt and abrasives and protect it while traveling. Always store the case out of direct sunlight. Direct sunlight will break down the silicone after years of exposure. 5. Periodically repeat the toothpaste treatment to keep the lens of your scuba mask clean. A good rinse after each dive helps to keep your mask clean, but to ensure there is no residue or grit left on your scuba mask you must properly clean it on a regular basis."
Scuba Diving & Snorkeling Logo
112 people viewed this question
Top mares Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a mares Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
