Question about Microsoft Wireless Notebook Optical Mouse VSBX300001
Computer says the mouse is working properly, but the light on the mouse isn't on and it doesn't work. put in new batteries and tried two different ports, still nothing
  • 3 Answers
I was having the same problem check if your mouse has a button on the bottom and your usb should have a button to right. ok so your first step would be to click the button from the usb once then wait about 5 seconds then click the button under your mouse once and that should do it.
Posted on Oct 29, 2009
How do I connect my Logitech wireless mouse to my computer
I use Logitech wireless mice and so does my wife. After a battery change you have to reconnect the mouse with the wireless receiver
. First push the button on the receiver, then push the button on the bottom of the mouse. It should connect and you will be ready to go. If this doesn't get the mouse working, you may have to unplug the mouse, then plug it back in the USB port, then reconnect to the receiver. Hope that helps.
Sep 30, 2014 | Logitech Cordless Mouse
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
I received a mickey mouse glove wireless mouse for the holidays. When I plugged the piece into the computer the mouse wouldn't work. Is there anything that I need to do to get started that I am not doing...
If there was a cd with the mouse, make sure you have inserted it and followed the installation steps.
The operating system compatibility for the product is Windows 98/ME/2000/XP/VISTA, Mac OS10.3 If you use a different one, it might be the reason why the mouse is not working.
If the red optical light is lit under the mouse and the USB transmitter is properly inserted, try pushing the button on the transmitter. If no change, try clicking the mouse buttons.
You can also try a different USB port.
If there is no red light, the batteries inside the mouse are either not inserted properly or dead.
Regards,
Jan 11, 2011 | Computers & Internet
My mouse isn't working
Try to put new batteries.
Apr 30, 2017 | Logitech 931150 Mouse
Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Sep 23, 2008 | Logitech Cordless Mouse
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
MS WNOM 4000
Make sure batteries are good and try
Jul 26, 2008 | Microsoft Wireless Optical Notebook Mouse...
First I'd reinstall the CD software that came with the Keyboard and mouse. Then I'd try the following.
Also check to see if you have enough memory to run all these functions.
May 16, 2008 | Logitech Cordless Mouse
Microsoft Wireless Notebook Optical Mouse VSBX300001 Logo
268 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
