Question about Ovens
How can I find a manual for a NEB Venezia HGSS?
How can I find a manual for a NEB Venezia HGSS FE8622EXX? Just moved to a flat that has one and there is no manual... Thanks!
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
Hi there. I have just moved in to a flat & have been asked if my stoves 050531075 gas oven is fitted with something called a FSD (Fire Suppresion Device) Would you be able to tell me please?
The are probably referring to an automatic fire extinguisher system, but from what I just read, the UK only requires a manual fire extinguisher to meet code.
The FSD would be fire extinguishers mounted on the wall instead of portable. They are only required in commercial restruarants.
Jun 08, 2011 | Stoves Ovens
Please can anyone help? We are in a rented property and we have an NEB Venezia SS electric oven with gas hob and all the writing on the knobs has been erased over the years. The hob works fine we need to...
Look up the oven on the web the knobs vari in calabration figures so I have never worked on this model, try a search engine you may find a showroom near you pop in and have a look.
hope this has been helpful
John
May 31, 2011 | Ovens
I have a NEB oven (.06) and need to check the bottom element to see if it's' working or not. Do you know how I can access this element as I can see no way to do so from inside the oven?
You do not access it from inside.
It is usually a case of removing a side panel to access the element, possibly the top cover as well.
Hope this helps you.
Dec 18, 2009 | Ovens
I need a manual for a neb verona ss fe2623exx oven
I have a manual for this oven which I can copy and email to get the grill to work you need to in this order.
Switch oven temp to max
then set function to grill
then set grill temp to what ever.
If you dont do it in that order the grill wont come on for some raeson.
Feb 26, 2009 | Verona Ovens
Ovens Logo
83 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
