It is like it want take the papper It has papper but it want take it it is like it is jamed
Samsung ml-3560 will not initialize
hi,please cheque printer papper jam & please take the jamed papper after printer is turn on to contiue see the error please replace the high voltage power supply
Mar 29, 2014 | Samsung ML-3560 Laser Printer
Entanglement papper
Sir/Madam
I suggest You Watch You Tube Video For HP Printer Entanglement Papper http://www.youtube.com/watch?v=9cCC0cCmBs8 or
Go To official HP Printer Website For Your HP Printer Problem Below Link On:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&dlc=en&lc=en&product=441125
In case You Still Having Hp Printer Problem and Need Online assistant Then follow Us On:
HP Printer Support
Feb 11, 2014 | HP Officejet 5610 All-In-One InkJet...
My printer has an error message that says document in ADF, what do i do?
Check in ADF of your printer, papper jamed probably.
ADF is in the top of your printer.
Jun 28, 2011 | Office Equipment & Supplies
Non stop papper jam what we do?
My first idea would be to clean the feed roll . I am not sure what more to tell you right now without knowing where it is jaming.
You may also want to confirm that the machine is displaying the proper paper size and proper orientation in the paper tray. Often times if the paper is stopping, without the paper being damaged, the tray settings are incorrect. Look on the machine display and confirm the proper paper size and orientation. Those trays flex a lot and that simply may be your problem.
Feb 19, 2011 | Xerox CopyCentre C118 Copier
What is error 77 and how do I fix it?
make sure its not jamed with papper blow out with air in can.
Feb 14, 2011 | Brother IntelliFAX 4100 Laser Fax
Incomming fax same page printing contenusly and wasting paper
put machine oil on papper roller let run a few pappers intell it gets worked in then see if paper is sticking if this doesnt work blow it out with air in can there has to be papper jamming the papper side.
Feb 13, 2011 | Ricoh 3310Le Fax Machine, FAX3310Le...
Paper jam
first of all cheq the location where is it jamed if in the start side may u have problem with papper feeding if after the registration rollers may any sensorr not working properly.
thanks
May 22, 2010 | Canon NP 6650II Copier
HP 8100 wrinkled paper
this is the problem of the fuser assembly, pressure roller part must be gone over their and also chance of tefflon sleve might be gone check and replace the part, the printer will work fine
Apr 21, 2008 | HP LaserJet 3030 All-In-One Printer
Papper jam.
There should be a door on the back of your printer, scanner, copier. Open that door and see if you have a paper jame there.
Apr 20, 2008 | Office Equipment & Supplies
Papper jam.
Open door to see whether do you do have any paper jammed. Sometimes, printer does not have a paper jammed but error still appears out of no where. Just open the door and close it again.
Hope this helps!
Apr 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
12 people viewed this question
k24674
