Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Cant see drive
I have installed a new hard drive -everything fuctions normally except for the seagate drive .I can not find it -have turn off and plug it back it but the machine doesnt recognize anything to do with this drive ?? does it need drivers or what else can I do ?
  • 3 more comments
  • burly Dec 18, 2007
    the removable seagate freeagent 250 gig drive -browny grey case with orange light up the front. The drive only has a power in and a usb port out.when I open add hardware it is showing there as working but will not show up as a drive when I open my computor .So in other words its a ghost and that I cant open or see?? Its driving me nuts.I see on the net its a common problem.I am not a tech head so would like a simple fix if one exits
  • Anonymous Dec 23, 2007
    I have purchased a Seagate FreeAgent Desktop 250GB external hard drive.
    Unpacked, plugged power in, connected to USB and turned on.
    Absolutely nothing happening on the laptop.
    Removed and did the same thing on the PC and also nothing happening.
    Please HELP!
  • thupham Dec 27, 2007
    I purchased a new removable hard drive (Free Agent Go 250). After have been using for a week, then, I could no longer see my drive (after I unplugged and replugged from my laptop). Please help.
  • Anonymous Feb 27, 2008
    comp shows hardisk is not detected press ctrl+atl+del
  • mvillarrea13 Sep 30, 2008
    yup, that is where I'm stuck. Ghost drive on the machine. Can't even get to it to reformat it. Does this on any PC.
Hey all,
I had the same problem with my FreeAgent 250gb external USB drive. My laptop would recognize the drive as drive "R:" with "x" amount of space used but when I clicked on it, nothing would come up. I ran all the disk utilities in hopes of "repairing" the drive and most of it didn't work. As a last resort, I ran a Norton Anti-Virus scan on the drive and sure enough, it scanned all the files that I put on there. . . . but was listed or "moved" to a different directory on the drive. I noted the path of where the files were then put that in the explorer address bar and sure enough, I was able to see and access my files again. Why it did that, Seagate support couldn't answer that question. So you might want to try that method.
Till this day, the drive has been nothing but problems as I'm not able to access it anymore. My advice (if not too late) is NOT to buy these as they are not reliable.
Hope this helps the next person. . . .
Posted on Jan 14, 2008
A couple suggestions that come to my mind are to check the drive itself for jumpers. Usually the drive will have a picture on it showing where to put the jumpers for a Master or slave or cable select drive. If you already have a main(master) drive, jumper this one as a slave. You say the drive is not recognized. Are you looking in the setup(bios) or at a dos command typing the drive letter with a : and it doesn't find it? You may need to go into Bios(usually F1 or F2 or del when it first starts booting up. Make sure it is enabled, select "auto" set up and hit enter for it to fill in correct settings. Drivers could possibly be a problem, the web site for the manufacturer may have them. Hope this helps.
Posted on Dec 18, 2007
Seagate 500GB FreeAgent GoFlex Hard Drive it didn't appear on my computer
RESOLVED!
Just because this starts with the same steps as other solutions does not mean it ends with the same fix.
1. Click Start
2. Right Click Computer: Select Manage.
3. The Computer Management Dialog box will appear.
4. Select the Disk Management Icon located in the right pane of the Computer Management Dialog box.
NOTE: Under volume you will NOT see the Seagate Drive.
5. underneath the volume pane you will see Disk 0, Disk1 and so forth. look for the Seagate drive ... mine was Disk 2.
6. Right Click on the Drive: Select Properties.
7. The "Seagate FreeAgent GoFlex USB Device Properties" will apear. Select the Driver tab.
8. Select the Uninstall Button.
9. Unplug your Seagate external hard drive and plug it back in. This should re-install the Drivers and it should work like it use to.
P.S. Sorry for the bad grammar\spelling.
May 09, 2012 | Seagate 500GB FreeAgent GoFlex Hard Drive
I cant find the installer for Seagate Expansion External Drive - hard drive - 500 GB, so i cant install this
Check with Seagates Customer support.
Should be an installer in their drivers section.
Possibly locate installer at www.driverguide.com
Jun 22, 2011 | Seagate FreeAgent Pro 500GB External USB...
My seagate 1TB external hard disk (the little compact one) cant be read anymore. Was working fine a couple of days ago. The lights on top are flashing constantly. After the drive is plugged into the...
Right click "My Computer" >properties> hardware> device manager. Expand "disk drives". Right click your seagate drive and click uninstall. Reboot your computer; the drive should automatically be reinstalled.
Feb 10, 2011 | Seagate FreeAgent Pro 1TB External USB...
My Free Agent Go shows up with a yellow exclamation point in "other devices" in device manager. It's not recognized anywhere else. I also notice that my computer says I have another hard drive...
> Seagate ST3200826AS
This is a Seagate 200GB SATA-interface disk-drive.
Open "My Computer", and point at the icon for 'C:' drive -- is it a 200GB disk-drive?
Double-click that "yellow exclamation" item. Click "install new driver" or "update driver".
If Windows asks permission to access the Internet to search for a new driver, allow it.
Note that the USB ports on some laptops are "weaker" (same voltage but lesser amperage) than USB ports on some desktops. So, your FreeAgent might not be getting enough power to function correctly. There exist 'Y' USB cables -- connect the 'Y' to 2 USB ports on your computer, to draw twice as much power.
Oct 31, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
New computer/ Lost Seagate operating instructions
Just plug it in and the pc should detect it as a external HDD and show up as one of the drives. You can copy all the data to it and transfer it to your new PC.
Apr 21, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
External hardrive 'cant be modified' on mac
since the windows and mac has different file format , u need to convert for support to mac systems
Oct 29, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I plug my seagate into the computer. it turns on but then nothing
Plug one usb into your computer and the other end into the drive.
If the light comes on, all is good. The computer should install the device for you automatically. To access the drive, go to My Computer and double click on the Removable Drive. Now you can transfer files.
Hope this helps
Chris (ziraffa)
Dec 28, 2008 | Seagate Free Agent Go Small 12 GB USB...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
409 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
