Question about LG LHD65EBL Dehumidifier
My dehumidifier is leaking. What to do. It was working fine up until the time it started to leak.
My Comfort-Aire Dehumidifier has started leaking water. The unit works fine but the water bucket does not retain all the water. As the bucket fills there are slow leaks. Also, sometimes when replacing the...
It can have leaks from the condenser to the bucket. The piping and hoses should be checked all the way. Perhaps even replaced or at least cleaned. I don't think it is wise to do this yourself. Because in the system also can be algae, bacteria and viruses. And you need tools and skills to replace defective tubes, pipes or gaskets.
Oct 10, 2014 | Dehumidifiers
Dehumidifier leaking
I have a duracraft DD-TEC16E I have had this for 12 months and has been working perfectly until today , I have noticed the water is not all collecting in the tank it's leaking on the floor . Any possible solution please?
Feb 14, 2014 | Dehumidifiers
Dehumidifyer freon leak
You can choose to ignore the toxic Freon leak and continue running your dehumidifier until the compressor fails due to lack of Freon, but why wait
Jul 01, 2013 | Kenmore 54701 Dehumidifier
Frigidare FDM70S1 The appliance is 3 yrs. old. It worked fine, but began to ice up. It's been in the same location for the entire time. The bottom half freezes up. The filter is clean. The fan works....
In your case you have a refrigerant leak and the unit is low on charge...unfortunately till you find the leak and fix it, then recharge the unit, you will have more money into the old one then to buy a new one...
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Sep 27, 2010 | Eva-Dry EDV300 Dehumidifier
My dehumidifier was running fine until the other day when the water would leak out rather then collect in the pan. Does this mean I need a new dehumidifier?
Before you go out and spend money, check the drain hose to see if mold may have built up in it blocking the drainage.
May 13, 2009 | Maytag M7DH65B2A Dehumidifier
Dehumidifier running but not producing water
Sounds like your relay switch isn't connecting....
Apr 29, 2009 | Maytag M7DH65B2A Dehumidifier
Leak
Mine did this last year. I took the housing off of the left side and found a clear plastic tube had popped off the fitting, I put it back on and it worked fine. The tube was toward the lower front of the unit.
Jun 01, 2008 | DeLonghi DE400 Dehumidifier
Dehumidifier leakage
My dehumidifier leaked after about one year of perfect operation. I unscrewed the face plate exposing the cooling grill and found out that debris was blocking the drainage hole that fed into the water bucket. The debris came from zip ties used to bunch some wires together. Apparently they got brittle (from the constant cooling and warming?), fell apart and managed to make it's way to the drainage hole. Cleared it out and worked fine again.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
LG LHD65EBL Dehumidifier Logo
75 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
