Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Refridgerator/freezer stop working
Gsh25jstass PROBLEMS - LIGHT is On and water works, all ice melted and it defrosted itself. fan comes on when door open, not getting cold at all.
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device,thermostat and main circuit board.
Posted on Sep 26, 2009
Samsung refridgerator rs261
If the temp in the 50/60 . To little info Freezer stop working. The first thing in Freezer side to melt is Ice Cream and Fish. 1st thing on freezer to check is the (Ice) Damper door closing all the way. Place a towel on floor and one when you get the ice. Get a 1/2 coffee cup of water pour in the shoot on top of the damper flapper if it hold water This is good. Close the door and remove the water by get ice. If the water pours out Not Good Replace the Damper assembly. It is letring in air and will freeze the evap up . 2nd there may be ice blocking the fan from turning. Bad sensor. Call Samsung get a tech out.
May 17, 2014 | Refrigerators
Seems the freezer door was not completely closed. Ice started ot melt and then form icicles! Well we closed the freezer the next morning. Now the ice maker and water dispensor are not working. In...
when you closed the door, the freezer froze all the condensation/melting ice,hence the icemaker freezing.
the best solution is a TOTAL defrost/clean out,then dry out.DO NOT USE HOT WATER/SCRAPERS,let it defrost naturally or use car de-icer.wipe out with bicarb to keep fresh.and then restart as new.
Sep 11, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Water dripping sound coming from new refridgerator
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan. This is the only source of water if nothing else is connected. Are you seeing and water anywhere.
Jan 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The refridgerator portion of my side by side fridge is luke warm. The freezer appears to be working fine. What can I do to fix this?
My guess is, your defrost timer has quit running and ice has built up blocking the passage of cold air from the freezer. It could be the defrost thermostat also, or just a stuck vent door. But I don't think so.
The defrost timer is under the refrigerator, accessible from the front. Normally, it turns on three times per day, turning on a heater element in the freezer, melting ice. The melt water runs down to a plastic tray under the refrigerator where it evaporates. When the freezer warms up, a defrost thermostat then turns off the juice to the heater.
Access the timer from in front. Use a screw driver in the manual advance slot to turn the timer till it clicks. Now it is defrosting. With ice buildup sufficient to block the air passage it may take a long time to melt all that ice.
If you dig into it and try to melt ice yourself, use a hair dryer rather than boiling water. That's what I've been told, although I used the boiling water.
Hope this works for you.
Dec 30, 2009 | Refrigerators
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Jul 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
368 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
