Question about Water Warehouse HIGH PERFORMANCE 2 HP HAYWARD SUPER PUMP -
Why does my pool motor keep burning out? I have replaced 2 new ones since march. I have a haward super pump and Emerson 2 hp motor
    President:
  • Water Warehouse Master
  • 1,378 Answers
What is your line voltage to the motor; 115 or 230? The motors come out of the box at 230 if it is dual voltage and if you are connecting it to a 115 V line, it will overheat and eventually fail.
If you are connecting it to the correct line voltage and setting the motor to match; check to be sure your voltage is not dropping under load. Check both line to ground to ensure both lines are sound.
When replacing the motor, are the seals sound or have you replaced the pump seal at all? Is it leaking?
Are the motors failing electrically or mechanically?
Posted on Sep 26, 2009
Hayward 3/4 hp pool pump keeps burning up
check wiring if ok check voltage if capacitors keep blowing high draw on motor replace whole pump
Apr 07, 2014 | Hayward Pool & Spa
Why does my haward c48l2n134b1 pool pump leak water on the bottom
There is a bearing between the pump motor and pump housing that tends to leak after time. Is it leaking in the shaft area?
Nov 29, 2012 | Hayward Super Pump 1 1/2 - Hp for In...
I need a replacement "Hi/Lo
This is a standard double pole double throw center off toggle switch. Get one at Radio Shack or other electronic parts store. You dont necessarily need the center off position ... btw. Double Pole, double throw will do it.
Thanks for your interest in FixYa.com
Sep 13, 2011 | Hayward Super Pump 1 1/2 - Hp for In...
My hayward super pump keeps tripping my GFI. The trouble locates to my pump
It could be an overly sensitive GFCI. If you replace it first, because it is cheaper than a motor, then you can determine whether you need a new motor.
I hope this helps.
Sep 11, 2011 | Hayward Super Pump 1 1/2 - Hp for In...
I HAVE A HAYWARD SUPER PUMP SELF PRIMING MODEL : C48L2N134B1 1 1/2 HP 115/230 VOLTS IT IS BROKEN AND I WANT TO KNOW WHAT MODEL I SHOULD BE BUYING TO REPLACE IT WITH. THE MODEL NUMBERS ARE DIFFERENT...
What is broken in your motor? Don't count it out until you have your pool place give it a check. If it is dead, get a 1 1/2 Hayward Super Pump just like the one you have.
Aug 11, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
My haywood pool motor is loud. Think it may be
Nope.... just replace the motor.... Some shops will redo bearings, but usually a 30 day warranty and a long wait.. Walk out the door with a new one with usually a 1 year warranty...
Jun 17, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
My 3/4 HP Emerson pool pump keeps tripping breaker
You did not say what the amp draw was nor what the amp rating on the pump motor was. Also you need to have the running volts tested to see if there is a voltage drop.
May 27, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Leslies put new 1 hp motor with old pump housing I put unit back in in ground pool but pump will not prime. used to work good but motor burned up. suspect leak between pump and screen area.pump works when...
Your pump is drawing air which is causing cavitation. Check all fittings leading to the intake. Then after that, pull the pump and re-seal the housing. That should be all.
Jan 15, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
New 1.5 hp super pump hayward, blows circuit when turned on...
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
Jun 11, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Water Warehouse HIGH PERFORMANCE 2 HP HAYWARD SUPER PUMP - Logo
391 people viewed this question
Top Water Warehouse Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Water Warehouse Pool and Spa Expert? Answer questions, earn points and help others
