Question about Mtd 22" Yard Machine Push Mower
Riding mower will barely move
42" riding yard machine slows way down in the middle of mowing, blades barely move
  • 437 Answers
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Posted on Sep 26, 2009
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When I finish mowing yard I disengage mower blades but they keep on turning why
If this mower has a manual lever that has to be pushed up in order to engage the blades then check the tension pulley that connects to the lever cable on the top of the deck,it probably need to be lubricated or cleaned in order to move freely back to the normal position.
May 14, 2010 | Garden
Lever that lowers the blades is stuck...in up/off position
did you check blade belt and check to see if blade is bent if not you have a broke blade houseing
Apr 17, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass.
Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
Jun 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
My riding mower workes fine fore about 45 mintes then it slowes down wants to move real slow and wont pull my yard sweper anymore. The blades engage just fine, the motor starts/runs fine It just moves slow...
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Craftsman ys 4500 throttle kill switch?
if you push it that far you are choking the motor
back the throttle back down to slow and try to start the mower if it starts go back to fast but not all the way to choke
Apr 22, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mtd 22" Yard Machine Push Mower Logo
290 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
