Question about HP Photosmart D7460 Printer
Printer thinks it is out of paper but it is not.
Have re-restarted and changed paper stock but every time I sent to print the printer thinks it is out of paper but it is not.
  • 32 Answers
Check the sensor button on the papertray , possible malfunction. as well reinstall all software drivers for the printer and perform updates.
Posted on Sep 26, 2009
Xerox 7760 Wrong paper size error when trying to print to A4
First your computer selects the printer to output to, so make sure your default printer is selected.
Next, within your printer you may have selected a different page size for output as a default.
The printer it self should allow you to load and auto detect paper size. If this feature is not enabled see if it is a choice.
Also whatever you are trying to print check page setup in the program you are using make sure to ensure they match.
Sep 16, 2016 | Xerox Phaser 7760DN Laser Printer
HP6500 won't print on foil
Most inkjet printers need a paper that has an absorbtion rate of +.ooo5 but unless the foil is a coated stock I dont think the ink will adhear to it..Try a differnt stock . Maybe a bad batch of labels..and did you use HP printer ink or are your cartrages refills??
Dec 20, 2013 | Office Equipment & Supplies
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
HP Photosmart 7550 - Full Page Photo Printing Jams at end
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 17, 2009 | HP PhotoSmart 7550 InkJet Printer
Paper jam constantly on
Jan 12, 2009 | HP Officejet 7130 All-In-One InkJet...
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Paper stuck
Jan 03, 2009 | Konica Minolta magicolor 2300DL Laser...
My 1280 cant print on card
perhaps this needs to be sent in from rear feed tray? usually higher stock papers won't bend as readily.
Jul 22, 2008 | HP DeskJet 1280 InkJet Printer
2600N: glossy paper
Is this HP glossy paper? I would think that laser printers have a hard enough time handling any glossy paper as it is because you run the risk of the gloss burning as the paper goes through the printer so you might have to use the paper recommended by HP.
Here are the specs of the accepted paper.
http://shopping.yahoo.com/p:HP%20Color%20LaserJet%202600n%20Laser%20Printer:1991823169:page=details
Good Luck!
Hope this helps!
Mar 07, 2008 | HP Color LaserJet 2600n Printer
HP Photosmart D7460 Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
