Question about GE DBXR463ED Electric Dryer
Loud rumbling noise with slight vibration
GE DBXR463ED2CC Electric Dryer makes loud rumbling noise when running. Noise does NOT stop after unit is warmed up. Everything else works fine on unit. It sounds and feels as if unit has a huge industrial grade motor now.
  • GE Master
  • 7,482 Answers
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Posted on Sep 26, 2009
LG DLE 2514W DRYER MAKES RUMBLING NOISE WHILE RUNNING
Hi Willie Bolden
Sounds like your problem is drum rollers are in need of lubrication or replacement.
Go to the following webpage for a schematic of your dryer and parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/parts-for-lg-dle2514w-abweeus.html
Oct 11, 2012 | LG DLE2514 Electric Dryer
Noise in operation. A loud rumbling noise when
Any noise must be identified with a good observation of the point of noise source.
This can be done with a good view with all safety precaution while the unit moves. Use good lighting and make sure that you are not putting your hands into any moving parts while the set works.
Now disconnect after observation and manually turn the drum, the motor and the rotor to fix the point of noise. this can be a faulty bearing assembly or a faulty suspension all of which will require a resetting/reassembly.
Feb 17, 2011 | Whirlpool LER4634J Electric Dryer
While running the dryer periodically makes a loud rumbling noise. GE DBXR463GD1WW
That rumbling could be worn or bad glides. 7efc7d5.jpgd3f6bc6.jpgb034ff0.jpgGo inthere and clean it up.ec417ea.jpg1e87790.jpegd4df180.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 22, 2010 | GE DBXR463GD Gas Dryer
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
My dryer is making a really loud noise when the clothes are spinning in the dryer. There is a loud rumble and squealling noise.
The squealing noise coming from your dryer is caused by the front glides located on the top bearing, they act like a pad against the drum and when gone, will make an awful squealing. part number for the 4 glides that may be needed is WE3X87 this is a common problem as it is a wearable part. if you don`t replace these in time it will grind all the way through your top bearing and start to deteriorate your drum. if its been like this for a while you may also need a GE drum bearing they come in short and long sizes. and are relatively cheap to replace.hope this helps
Thanks
Oct 11, 2009 | GE DBSR453EBWW Electric Dryer
Ge dptg750ec make loud rumbling noise after replacing blower
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 09, 2009 | GE Profile Harmony DPGT750EC Electric...
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Hi, my GE model DBXR463ED1WW dryer is LOUD!
Roaring could be an over firing burner or fan related. Squeak or rumbles are bearings. Is the noise all the time or only when the burner is on? Eric
Jun 20, 2009 | GE DBXR463EBWW Electric Dryer
GE DBXR463ED Electric Dryer Logo
627 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
