Question about Cameras
My casio Ex-S10 wont open
When i turn it on it makes an unusual sound and then closes. The only time it'll let me keep the camera lens open is if i press the pictures button right when i turn it on. But even then it closes after 7 seconds
SOURCE: Casio EX-S500 Lens Error
Remove the Back and front covers, then use a small flathead screwdriver to release the 2 hinges that hole the lens assy down; then unlatch the 2 ribbons cables. Now you can install the new lens assy. If you're not going to use the "old lens assy, can I have it, please? Thanks.
Posted on Feb 05, 2008
SOURCE: LENS ERROR 2 on my Casio Ex-V7
I read on the Casio website that this is due to an impact, meaning, the camera must have fallen or hit something really hard and strong.
Lens error 2 indicates that there is something wrong in the lens assembly. One possible damage concerns the image stabilization mechanism.
I also own a Casio EX-V7. My sister dropped it so hard that a dent has appeared on one of the front corners. Everytime I switch on the camera on record mode, LENS ERROR 2 appears for a few seconds.
Despite this, I can happily use the camera as usual. However, it's just annoying to see the Error.
I'm planning to bring it to a service center within a month from now.
Posted on Jul 18, 2008
hemantraj
  • 638 Answers
SOURCE: My Casio X10 lens was
open all the screws with proper screw driver it will disassemble.
and take care of the plastic locks.internally.
thanks,
Posted on Sep 01, 2008
  • 11967 Answers
SOURCE: My casio ex-s10 won't turn on. It beeps and beeps
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
  • 73 Answers
SOURCE: i have a Casio EXILIM EX-S10 "Memory Full" Error
Firstly, charge your battery fully. This should solve the switching off. It sounds to me like your card isn't in correctly, or is incompatible, and your internal memory is full. (it usually only stores a few photos for emergencies) Have a look at the type of card you have. If it says SDHC, or is 4GB or larger, it is not compatible with your camera and you need to get a 2GB. If not, it may not be inserted correctly. Push it all the way into the slot and it will click when it's in properly. Then try formatting it. Press review (where you look at the photos) and scroll down to setup- then look for 'format' and press okay. This should sort everything out. You can also copy the photos you've taken in the meantime from the memory to the card by pressing copy in the review menu and scrolling to the right. Hope that helps
Posted on Jul 26, 2010
My casio EX-S10 lens stuck out and wont turn on even with battery recharged
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
Nov 14, 2011 | Casio Exilim Ex-z300 Z450 Z9 Z80 S10
Casio exilim EX-S10 wont turn on and lens stuck out
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here is a video summary of the steps:
Focusing Problem
hi, if you can open your camera and remove the lens unit assy(just be carefull to the flat cable its easy to be broken) you can clean by yourself just to remove the sand goes inside of the lens unit and also to the gear.make it sure you need to use magnifying glass to see the small pc of sand .some time the sand goes to the gear that cause of malfunction or not rotate properly and also the focus gear have also sand that why the focus is bad.if you can't do this just bring to service center and request for cleaning.
thank you
Jun 19, 2010 | Casio Exilim Card EX-S100 Digital Camera
Taking photos with casio ex-s10 goes all white
It don't work shutter. You need in repair lens unit.
May 16, 2009 | Casio Exilim EX-S500 Digital Camera
I have a casio exilim ex-z60 and i accidentally drop with the lens was on, and now its stuck it wont going back(close) dis align the lens, what can i do?
try taking the battery out, and then putting it back in, and hit the power button a few times.
i drop my camera all the time.
make sure your battery is charged before you declare it broken.
[hahah, i did that once]
Nov 26, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Mar 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Cassio
Sounds like you have a lens error. THat needs to be sent into repairs to be fixed.
Mar 12, 2008 | Casio Exilim EX-S600 Digital Camera
Casio ex s600
Sounds like a lens error. Try taking battery out and putting back in. If it still wont go in then u r going to have to send it into casio to have it fixed.
Nov 11, 2007 | Casio Exilim EX-S600 Digital Camera
Lens do not open
More than likely lens is off track. send into casio to have it fixed.
Oct 19, 2007 | Casio Exilim EX-S600 Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
