Question about Ovens
Duco4ss main oven not heating on fan setting
the main oven in my duco4ss will heat on the upper element setting but we get no heat on the fan setting. The light comes on and the temperature light shows that the oven is (not surprisingly) not at the desired temperature. I have tried using a range of temperatures but to no avail. Is it the fan element or should I try some other switches etc first?
13 coming for Christmas dinner and 12 at New Year!!!!!! Any help gratefully received
Pete
  • helsby Dec 19, 2007
    main fan oven not heating. fan does appear to be running but the oven is not heating at all. Oven light is on.
Buy a new cooker!!! i have a neff oven and i am on my 5th element in 18 months!!!!!! nice looking double oven but absolutely useless, cheaper to buy a new one!!! would never buy neff again.
Posted on Feb 09, 2008
    Champion:
  • 249 Answers
Put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Posted on Dec 18, 2007
SMeg duco4ss wiring diagram
Request a wiring diagram for model duco4ss directly from Smeg.
May 13, 2018 | Smeg Ovens
Fan and element not working
hi not sure if you've had a reply but when my zanussi main oven stopped working i just changed the element (purchased from e bay).
open oven door and the back you will see 4 screws(basically 4 corners) remove these screws and you will see the element, pretty straight forward to remove, obviously fan wont work until you have heat (hopefully fan ok) you can give this a go, cheaper than buying a new oven. i have done this twice. hope this helps.
Mar 10, 2014 | Zanussi ZHQ575 Electric Double Oven
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Fan assisted oven is not heating up
Hi.
Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
Please `rate my solution.
Thanks.
Jul 28, 2009 | Ovens
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Ovens Logo
268 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
