Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Stops cooling ice melts and leaks water on the floor
GE side by side refrigerator Model GSH25JSRFSS seems to stop cooling possibly in defrost mode and temperature in refrigerator and freezer rises causing everything in the freezer to thaw and the ice melts in the icemaker. Eventually it begins to cool again. Sometimes I have to unplug the refrigerator and then plug it back in to get it to start cooling.
  • GE Master
  • 4,654 Answers
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Posted on Sep 26, 2009
The freezer has ice covering the bottom and it melts and leaks out on my floor?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice is forming on back-bottom of self-defrost freezer in side-by-side unit. Ice melts and leaks onto floor in front of unit. Unit is about 10 years old.
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrig. Water leaking on floor after ice maker stopped
look at water delivery tube to the ice mker . it has iced over and pluged up causing the water to go out the back and down on floor . . clear the water tube with hot water and problem is over . .. some models cah use a updated water tube. mm
Jul 16, 2010 | GE GSH25JFR Side by Side Refrigerator
We have a GE refrigerator that is leaking
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 07, 2009 | GE GSS25JEMWW Side by Side
Cooling sometimes, freezer leaking water when it stops freezing
It is probably the defrost thermostat located on upper condenser coil to the left of the fan in the freezer compartment. If not, it could be the defrost timer located near the thermostat in the refrigerator under the plastic dome where the light is. If the defost thermostat or defrost timer is not cycling the defroster heater element on and off correctly... an ice dam forms clogging the drain tube which freezes and blocks water (from the the defroster) to draining down and into the evaporator pan located on top of the compressor in the rear of the unit near the floor.
Mar 31, 2009 | KitchenAid Refrigerators
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
395 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
