Question about Bosch SHU3306UC Built-in Dishwasher
How do you attach the spring to the back of the detergent dispenser to the lid of the dishwasher so it opens and closes properly.
  • lauraodegaar Sep 26, 2009
    We have the spring, but I don't see what appears to be the O-ring in your picture? I am able to attach the spring on the detergent dispenser lid, but spring action seems to strong and lid will not remain closed. The diagram you sent is too small to read. Is it an O-ring and where should I place it?
    I have the spring, but do not have what appears to be an O-ring in your picture. I have attached (not sure properly) the spring on the lid of the detergent dispenser but it is too strong and won't close. Do I need an O-ring? The diagram you sent is too small and unreadable.
    President:
  • 1,462 Answers
This can be tricky with sharp edges and avoiding damage to the inner door.
Remove the outer door with a T-20 torx driver. Remove 2 long screws in the top corners then remove the 6 short screws (3 each side).
Close the door and slide the outer door down and out to remove. There are some plastic block that sit on the hinges that probably will fall off they just slide back one. There for shipping so they don't need to be replaced if you can't get them back on.
Now you can see the dispenser. It is held in by a series of tabs formed by the inner door pressed into stepped ridges on the dispenser. You need to bend these out and the dispenser will pop out the door into the unit.
Now the hard part is getting the new dispenser put back in. Slide the new one back into the opening from the inside of the unit. Bend the tabs back into the dispenser take care not to bend the door as you can get a leak around the dispenser seal.
Please leave me comments, if you need furthur assistance
RNJ VINODKUMAR
Posted on Sep 26, 2009
  • Bosch Master
  • 19,396 Answers
The spring is hooked on one side on the detergent drawer, and on the other side is assembled with the door lock pin below:
Use the diagram below:
Why detergent door doesn't open on quiet partner 111
The detergent dispenser lid spring may be stuck or the solenoid faulty. Might have to replace the detergent dispenser.
Best to check which one of these two might fit your model.
http://www.whirlpoolpartsonline.com/dishwasher.html?cat=35
Jul 30, 2014 | Whirlpool Dishwashers
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
Dispenser cover does not close properly
Usually you would not reconnect the spring in the unit due to most likely the spring is now outstretched and would just end up falling off again even if you did put it back to where it belonged. If on the other hand you can tell that the spring is not outstretched you would need to provide the make and the model number of your unit in order for me to properly tell you how to put the spring back in place. Most of the time when the spring does let go it is far more easier to just replace the soap dispenser itself rather then going through the headache of trying to attach the spring and having it fall off once again. I am also attaching a youtube video on how to change the dispenser as well but here is the link if it does not
http://www.youtube.com/user/RepairClinic?v=m-nJ6C1ShfI&feature=pyv&ad=7605158741&kw=dishwasher%20dispenser
if you have any further questions message me back.
Thank you
Rick
p.s if you need me to look up the part number for the dispenser message me back you make and model number
Nov 19, 2011 | Dishwashers
I have a bosch dishwasher model number SGS0902GB/05. I use tablets instead of detergent. I put the tablet in the Dispenser and close the lid, noproblem. I then set the programme and shut the door, I...
Hello Andrew,
I'm more than happy to give step-by-step instructions for replacing the detergent dispenser, however it's not cheap (about £50) and it probably doesn't need to be replaced. Some of the smaller components for the dispenser are available separately, so it would be better to work out what's wrong with it, before replacing any parts - or the entire unit.
The dispenser may be receiving an erroneous signal from the controller to open when the dishwasher is in delay start mode. To check this, switch the power off, insert a tablet in the dispenser, and slide the door closed. Make sure it clicks shut fully (push on the arrow on the door)and then wait for a few minutes to see whether it opens.
If the tablet will stay in the dispenser with the power off, there is nothing wrong with the dispenser. If it opens with the power off, you may just need a new dispenser door or a spring. Please try this simple test, then get back to me for further assistance.
Regards,
BElectric
Apr 12, 2011 | Bosch Dishwashers
Detergent door not opening properly so not washing well
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Jan 14, 2011 | Dishwashers
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU3306UC Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
