Remove the base of an lg 47lbx flat screen - Televison & Video
3 Suggested Answers
SOURCE: Remove Base from Toshiba Regz 42RV530U
I bought this LG flat TV at Circuit City last week. TV is okay, but I was trying to hook up my portable DVD player and I can not make it work. I can hear the sound that coming out from the DVD but theres no picture from the screen. I believe my connection is correct, because there is the color coding which is red, yellow and white which you just connect at the back of the TV and at the DVD player.
Can anyone help me to figure out the problem. thanks a lot
Posted on Jan 31, 2009
mnwarfield10
  • 452 Answers
SOURCE: HOW DO YOU REMOVE THE BASE ON A 42" FLAT SCREEN
you will have about 4 -7 screws on rear of tv ... normally there a bit bigger than rest ...
Posted on Feb 27, 2011
I have the language set up but I cannot receive the captions. How do I do this?
try going to onscreen menu , scroll around till you find a caption option and turn it on
some remotes for the tv will have that option in a button
Sep 17, 2016 | LG LCD TV Remote Control MKJ39927802...
Lg volume problems
The contacts between the carbon of remote and the rubberized button could be faulty.
Jul 19, 2014 | LG LCD TV Remote Control MKJ39927802...
HOw do I remove the base from a LG 32LK330 flat screen TV
Lay the tv screen facing down on something soft like your sette or bed so the base is hanging over the edge.
At the back you should see screws on the base, if not visible they will be under a cover which should prise off
Dec 31, 2013 | LG 32LK330 TV
Want to take base stand blanking piece off to fit stand on Lg 32 inch flat screen tv
You haven't supplied the exact model, but with most LG blanking covers they are usuall removed by a levering a plastic clip at the side of the cover & then simply pulling the cover forward.
Dec 26, 2012 | Televison & Video
How to remove base so it can be wall mounted
Put LCD TV on a pillow, with screen resting on the pillow. Now the base will be free in air. Then remove screws at the back of TV, where base is joining. You might need a screw driver with magnetic head to remove screws. After removing screws, slide the base clamp out from the back of TV, and you are done.
Nov 01, 2010 | LG 32LG30 32 in. LCD HDTV
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
How do I remove the swivel base?
Steps to remove swivel stand:
  1. Carefully place the product screen side down on a cushioned surface that will protect the product and screen from damage.
  2. Remove the 2 screws that are vertically in line next to the power socket.
  3. Remove the 2 screws that are vertically in line under the RGB socket.
  4. Pull the stand out from the bottom of the TV.
  5. Reinstall the stand in reverse order.
Nov 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Remove base from LG 42LG50
Hi, I don't have the solution (sorry!) but I do need a base for the 42LG50. Would you consider selling yours to me once you remove it? My email is lbailey13@gmail.com. Please let me know. Thank you and good luck!
May 12, 2009 | LG 42LG50 42 in. LCD HDTV
Jan 31, 2009 | Toshiba REGZA 47HL167 TV
Remove Swivel Base on 42LB1DRA
If you look at the back of your TV, locate four big screw/bolts. Its the biggest screws/bolts you'll ever find at the back. 2 each side that holds the unit to its swivel base. roughly 12" from the left edge and 12" also from the right edge. remove all this four (4) screws/bolts then ask someone to help you lift from the base.
Good Luck.
Dec 30, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
266 people viewed this question
Top Televison & Video Experts
Electro Med Services...
