Question about Black & Decker Simple Start Car to Car Battery Booster
Looking for an instruction guide for a ''Challenge'' jump starter for Cars. The red switch on the model has three positions OFF/CHARGE/ON. I need to know which switch is to recharge the car battery and not charge the actual jump unit. Also, how will i know when the battery is charged?
    President:
  • 1,714 Answers
The 'ON' position is for charging OR jumping the car battery. Normally, you just hook the unit to the car battery to jump start it, then remove it and the car alternator will charge the car battery.
Posted on Sep 26, 2009
I have a vector 300amp that will not charge or hold a charge.This is the first time i needed a jump start my car and did not work! It was fully charge. It must be a Manufacturer defect!What to do? You
The FIRST question to answer is, how old is it? If you have had it, unused, for much more than a year, then you shouldn't expect it to take and hold a charge, unless it's got an advanced battery system installed that is. Most of these are produced 'down to a price', not 'up to a standard' and are equipped with lead-acid batteries. As many will know, lead-acid batteries soon lose their ability to take and hold charges unless they're put into immediate and regular use. However, if yours is inside a year old, then you might just have some come-back. Make sure to read the instruction book. You MAY find it says 'charge it immediately ... etc!
Jan 26, 2015 | JUMP START SYSTEM
I have a D5805 STARTER-UP 400 Jump Starter and need instructions for it. where can I get them.
you can buy one at any good car sale shop and make sure you
read all the instructions before useing it as jump starting is always fit red [POS] cable to both cars or batterys first and then fit the black cable lead last,when finished remove the Earth lead [black]First with car doing the charging turned off.
When charging car to car let engine run for approx 4 minutes at 800 rpm then let it idle for 2 minutes before starting the second car
Nov 16, 2014 | Cars & Trucks
How can tell if a silanoid bad on my riding mower
After assuring battery is charged and all electrical connections are clean and tight, you can try this,
If your tractor has the external solenoid (separate from the starter), you can by pass this solenoid by jump starting the starter with booster cables.
Negative cable will go on neg post of battery to a good ground on engine and then positive cable on positive post of battery, then just touch the other positive end to positive starter post (where the large cable is connected from solenoid). If the starter engages, chances are the the solenoid is bad or could be ignition switch is bad.
Oct 02, 2014 | Garden
Left the lights on on a 2008 jeep Grand Cherokee laredo ... got a jump and door dinger dings and lights come on while jumping but will not start.
did u follow the correct way to jump that var/suv?? there is a method,ground to the block,and pos to the pos side of the battery. then lit it charge for a few minutes, then giv it a shot. u r battery is probably beat down to nuthin. so git it towed and then u will need a new battery.??maybe? lol
Apr 13, 2014 | 1992 Jeep Cherokee Sport
2006 Cobalt ss will not start
The key is chiped , does it have a padlock an car symbol light on the instrument cluster when you turn the key on ? Do the headlamps work ? shine bright ? Do you have a volt meter ? Check battery voltage . Go to http://www.bbbind.com/free_tsb.html free wiring diagrams . Enter vehicle info. year , make , model an engine size . Under system click on electrical distribution , under subsystem click on power distribution . Check power at the crank relay , plus you need to know what happens when you turn that key to start . Computers involved .Do you know about relays ?
Moving the ignition switch to the START position signals the body control module (BCM) through discrete inputs from the ignition transducer that engine crank has been requested. The BCM verifies that theft is not active and sends a serial data message to the engine control module (ECM)/powertrain control module (PCM) requesting engine start. The ECM/PCM receives a 12-volt signal from the park/neutral position (PNP) switch or clutch pedal start switch notifying that it is safe to start the engine. There is a splice on this circuit in the fuse block-underhood that supplies power for the starter relay coil. The starter relay coil control circuit is then grounded by the ECM/PCM closing the switch in the starter relay suppling 12 volts to the S-trminal of the starter. Ground is supplied through the engine block.
A scan tool of professional type would be a good tool to have to diagnose this .
The vehicle theft deterrent (VTD) system functions are provided by the theft deterrent module (TDM). When an ignition key is inserted into the ignition lock cylinder and the ignition is switched ON, the transponder embedded in the head of the key is energized by the exciter coils surrounding the ignition lock cylinder. The energized transponder transmits a signal that contains its unique value, which is received by the TDM. The TDM then compares this value to a value stored in memory. This is the learned key code. If the value is correct, the TDM sends a random generated number to the transponder. This is called a challenge. Both the transponder and the TDM module perform a calculation on the challenge. If the calculations match, the TDM sends the start enable message via the serial data circuit to the engine control module (ECM). If either the transponders unique value or the calculation to the challenge is incorrect, the TDM will send the start disable message to the ECM via the serial data circuit. The components of the VTD system are as follows:
• TDM
• ECM
• Ignition key (Transponder)
• Ignition lock cylinder
• Security indicator
Is the light on . when trying to start the vehicle ?
Mar 14, 2017 | Chevrolet Cars & Trucks
I have a homelite 720 generator but cant fingd the instruction manual and i need to know if the charger leads only charge a battery or can be used as jump leads i know this might sound stupid but i wo
I can't find any reference to a Homelite model 720 generator but most battery charging systems do not supply enough amps to run a car starter. Battery chargers usually work in the two (trickle) to ten amp range. Car starters need way more amps to have enough power to turn an engine over, depending on the size and number of cylinders in the motor. Some chargers have a switch with a 60 amp 'start' position to help the battery turn the motor over, but without that there is little chance the charger side of your generator will supply enough amps to help your battery.
Feb 21, 2012 | Cars & Trucks
The car won"t crank, 1992 Volkswagon Passat
If the switch (neutral safety switch) is broken, it will not crank regardless whether you jump the battery or a new battery is installed. I don't have specific manual for your year that's why my advice is as in general. With a remote starter tool, bypassing the solenoid wire with remote starter which is connected to the positive terminal of the battery of it's other end. Once positive current flows from the battery, through the remote switch, flowing towards the solenoid, the starter should engage indicating a bad wiring harness connection from ignition switch. If it doesn't crank at all you may have a bad starter assembly and needs replacing. If your starter is clicking using it's own battery power, your battery is low of charge or your charging system is malfunctioning.
Pls, rate this suggestion, thank you.
Jul 23, 2010 | 1992 Volkswagen Passat
Bought new starter for my 97 neon due to always needing jump now car wont crank just clickin noise so bought new battery now wont do anything not even click could I need an alternator?
Jump atart the car or charge the battery to get it running again. With the engine running, check the battery with a voltmeter. Should be around 13.5 to 14.0 volts. If significantly less, I would suspect alternator or wiring. Also check the lone fat red wire coming off the positive battery terminal for corrosion - replace the eyelet if it doesn't look clean.
Jun 27, 2009 | Dodge Neon Cars & Trucks
Black & Decker Simple Start Car to Car Battery Booster  Logo
425 people viewed this question
Top Black & Decker Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Black & Decker Electrical Supply Expert? Answer questions, earn points and help others
