Question about Pioneer DEH-P690UB CD Player
Poineer III D wont turn on
Recently i was doing elecrtical work on the my Jeep which required removing different fuses from the car. When the fuses were replaced and the car turned beck on, the whole radio/clock system wont turn on and is completely unresponsive. All the fuses are in correctly and the radio its self was never disconnected from the car.
    Scholar:
  • 67 Answers
If the negative ground was not disconnected, you may have popped a fuse on the radio, if it has one. Check the back of the radio and the fuses there. Always remember to disconnect the ground when working with the electrical system.
Posted on Sep 29, 2009
2002 Jeep Liberty 3.7L Engine Swap to newer 2005 engine
every year the motor had different parts and timing was moved. try and take parts off the old motor. like the fuel rail and the sensors
Jan 07, 2013 | 2002 Jeep Liberty
What kind of transmission fluid do I have to use
If this jeep is listed correctly, as a 1996 jeep Cherokee country then the correct transmission fluid would be Mercon or Dexron III . this is the correct fluid, Also if you remove the transmission dip stick and wipe it and look at the stick it will say dexron III. good day
Apr 14, 2012 | 1996 Jeep Cherokee Country
If while the battery is connected and the started isn't one accidently touches the battery feed wire to the metal frame creating a spark and thereafter no power is flowing throughout the vechicle what...
Check the fuses, it will be a 40amp or 60amp, they are most likely under the hood in the fuse box, follow the possitive battery cable to the elecrtical box, replace blown fuse.
Jun 30, 2011 | 1998 Jeep Grand Cherokee
Instrument cluster not working but jeep runs fine
Often the whole instrument cluster runs off of the same fuse. Did it just recently stop working? If so, has there been any work done recently to the stereo or any of the dash controls?
A fuse blowing just because it's worn out, or old, is not very common. Most fuses are damaged from electrical work being done and someone accidently touches something that sends an electrical surge which blows the fuse.
You should be able to remove the fuse cover, inside the car on the driver's side. When you remove the cover most have a fuse diagram on the inside of the cover.
I hope this helps.
Jan 26, 2011 | 1998 Jeep Cherokee
Clock and lighter do not work. elecrtic miiors
You need to replace the fuse. Look in your owner manual under index and look for fuse box location. Remove the fuse box cover and find the fuse that states cigar lighter or mirror. Remove that fuse and replace with new 15 amp fuse. Your fuse box should have a fuse puller and auxilary fueses
Jan 06, 2010 | 2000 Toyota Camry
Power brakes won't work
was the car sitting for a while?The booster may be at fault.Caliper sticking?Fuses have nothing to do with your problem.It is a brake line problem.Could be a few different small problems.Easy to fix though.Hope this helps you
Nov 18, 2009 | 1999 Jeep Grand Cherokee
Drivers side door on 1998 jeep grand cherokee stoped working ,doors wont lock , window wont roll down , mirrors dont work , is there a fuse to check ? and where , i know where the fuse box is dont know the...
I have the same problem. Do not know cause but I remove large red 50 fuse in engine compartment fuse box, wait 15 sec and replace. Lock car and unlock. This seams to reset something and car is fine. This problems seams to appear when my battery is low.(?)
Oct 26, 2009 | 1998 Jeep Grand Cherokee
Golf III wont start
check the crank sensor before going to the ECM also check the fuse link and check all fuses
Apr 19, 2009 | 1994 Volkswagen Golf
1997 Jeep Grand Cherokee fuse layout
you may have to pull each one until you find the one thats burnt.there may be more than one fuse burnt so id replace any that are bad
Jan 21, 2009 | 1997 Jeep Grand Cherokee
92 jeep wont start when cold outside
take and remove your computer on the driver side under the hood. it requires a 5/16 socket or wrench( sockets are faster.) be very careful when removing the computer. after you have removed the computer, take it inside where it will get warm( next to a heater or fire place (DO NOT LET IT GET TO CLOSE TO AN OPEN FLAME!!!!) After taking and letting it warm up after a few minutes ten to 20 then reinstall the computer making sure not to bend any of the pins.try that. if that works then you will need to replace your computer.i hope it works cause that is what was wrong with mine.
Nov 21, 2008 | 1992 Jeep Cherokee Sport
Pioneer DEH-P690UB CD Player Logo
197 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
