Question about Jeep Watches
NEED TO ADJUST LEGNTH OF JEEP WATCH STRAP. NO
NEED TO ADJUST LEGNTH OF JEEP 5 ATM BRACELET TYPE WATCH STRAP. NO INSTRUCTIONS GIVEN WITH NEW WATCH
escapement
  • 2334 Answers
SOURCE: how to adjust metal bracelet on casio A168 watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 05, 2009
  • 40 Answers
SOURCE: Caravelle by Bulova watch strap adjust
You need to push the pins out in the direction of the arrows. Then take out one link from each side. Put the pins back in the same way they came out, with the slot pointing the same direction as before.
Posted on Feb 26, 2007
SOURCE: fossil watch me1001 bracelet adjustment
I took mine to a watch store, and had them remove a link.
Posted on Dec 26, 2007
SOURCE: Can't figure out how to change watch strap
Hi, try this - it worked for me. Use a needle to poke the ends of the watch strap axel (at the end and running across the strap). This should then allow you to lit the silver panels at the top and bottom of the watch face off. The axel should then slide out. I did this by pushing one end of it through with a needle so that the other end poked out enough to pull it out with a paid of pliers.
Posted on Mar 24, 2008
dmbgo
  • 58 Answers
SOURCE: How do I remove links from stainless steel
The band has pins in it which can be removed by tapping them
Posted on Jun 22, 2009
Omega 196.0167 cal 1342
The watch part number and a knowledgeable watch maker will provide the correct bracelet. If you WANT a leather strap most models can accept one - unless the case is sculpted to integrate seamlessly with the bracelet, in which case you may not be able to insert the spring bars that are necessary to mount the strap.
Sep 09, 2012 | Omega Watches
Adjust bracelet on sea spider?
Thank you for contacting FIxYa.<br /> I suggest you take your watch to a reputable local jeweler for sizing. Expect to pay a nominal fee (around $5) for this service. Do not attempt to size your own watch! You may damage or scratch the watch and bracelet. The liability is yours.<br /> If you still decide to do, follow instructions given here:<br /> <a href="http://www.webwatches.co.uk/how_to.htm" target="_blank">http://www.webwatches.co.uk/how_to.htm</a><br /> Best wishes. Jewel
Aug 26, 2010 | Invicta Watches
I need to buy new bracelet
mcdevito75 here, BEST BET for your Ebel watch, look for a small watch repair shop in your area, to order a new bracelet.
Jul 13, 2010 | Ebel Type E Stainless Steel Rubber Strap...
Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
I would like to adjust my Pulsur watch strap but I cannot push those tiny screws on the strap
To do that you need a hardened steel pin and small hammer. Use that pin as a chisel and drive the bracelet pins out. Split pin end must come out first. When driving pins back in- blunt end goes in first and split end last.
You can make driving pin from hardened needle by blunting the pointed end.
Dec 17, 2008 | Watches
Hi, where can i get a new casio mtg-900 watch strap/ bracelet? thanks Nathan
good eafter noon ! you can buy a bracelet of your watch on casio center near you,thanks!
Aug 28, 2008 | Casio Watches
Remove few pieces in my Casio AW-SD bracelet
What u can do is call casio tech support and give them ur email address and they can send you the instructions to adjust your band.
Jun 07, 2007 | Casio AWS90D-2AV Wrist Watch
Watches Logo
224 people viewed this question
Top Jeep Watches Experts
Jimmy Accardi
Are you a Jeep Watch Expert? Answer questions, earn points and help others
