Question about Nokia N95 Cellular Phone
My n95 some one not expert tri to unlock it to me but when he restart it the phone just turn on for 5 second on wight screen with NOKIA word as normal then it turn off alone and the scren start going slowly, i triedto fprmat it by pressing (call,3,*0but it turn off without any effect, is there any solution? thanx alot
    Problem Solver:
  • 12 Answers
Try using these free sites:
www.trycktill.com/eng/
www.unlock.nokiafree.org
www.unlockitfree.com
Good luck!!
Posted on Sep 27, 2009
My n95 is not turning on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 15, 2012 | Nokia N95 Cellular Phone
Pls how can i flash my nokia N95
No matter what network your Nokia N95 phone currently runs on, you can unlock it---or "flash" it---to run on any GSM network. You will only be able to use your unlocked Nokia N95 phone on networks that use SIM cards---such as T-Mobile and AT&T---and not on CDMA networks such as Sprint and Verizon, which do not provide SIM cards.
Read more: How to Flash a Nokia N95
Unlocking the Handset
Remove the back cover and the battery from your cell phone. Locate a silver sticker with a bar code on it. Take note of the 15-digit IMEI number printed on it. At this time, also remove the SIM card and write down the numbers printed on the back of it. The SIM card is the small, white data chip in the silver cradle right next to the sticker. You will need these numbers to obtain your Nokia unlock code.
Request a Nokia N95 unlock code from your service provider. If they cannot provide you with an unlock code, you can buy one online.
Replace the SIM card, battery and cover. Fully charge your handset.
Turn on your handset and type "#PW+".
5
Enter the unlock code given from your phone company or website. Make sure you dial the number exactly as it was given to you. If you dial this number incorrectly three times, you will be permanently locked out of your handset.
6
Dial "+1#". At this point, the screen on your Nokia N95 should read "SIM Restriction Off."
Inserting SIM Card
Switch your handset off and remove the back cover and battery.
Remove the SIM card.
Insert the new SIM card into the SIM card slot. Now that the phone has been unlocked, this can be a SIM card from any U.S. service provider that uses SIM cards.
Replace the back cover and battery and switch the cell phone on. The screen should now read the name of the new service provider
Nov 30, 2011 | Nokia N95 Cellular Phone
My Nokia n95
Tom,
There are two things that you could do. One is to power cycle the phone and to bring it to the Nokia.
To power cycle it, please follow the steps below:
1. Turn off the phone.
2. Remove the battery, SIM card and the memory card.
3. Leave it for about 5 minutes and then put everything back to the phone.
4. Restart the phone.
If same problem persist, bring it to the Nokia Care Center near you for possible firmware upgrade.
Have a great day!
May 25, 2009 | Nokia N95 Smartphone
My nokia n95 turn to white screen.
Power off phone. Press and hold Green, * and 3 and keep them held whilst powering on and for a few seconds after
man the code written is hard reset for n95 **** .there is a hardware problem in the cell phone you need to change the strip of ur cell phone which connect the upper and lower portion.
Jan 30, 2009 | Nokia N95 Cellular Phone
Unlockig code
and follow the steps
Howto use:
You need two mobile phones.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card (MMC) from the locked phone and put it into a
second mobile. Install FExplorer on the second mobile phone. Create
the directory E:SystemRecogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345
Aug 03, 2008 | Nokia N95 Cellular Phone
Nokia n95 screen problems
Try a hard reset on the device. Pull the battery out whle the device is on. Then put back in.
If that doesn;t work, try reloading the OS.
Jun 02, 2008 | Nokia N95 Cellular Phone
Frozen on the main start up screen
try restarting your phone and turn it on using safemode.
you need the Nemesis Software Suite, download it here:
http://www.megaupload.com/?d=093RM931
hope this helps.
fixya!
Jan 30, 2008 | Nokia N95 Cellular Phone
Nokia N95 Wont start up properly
hi to all u wot r having the same problem i email nokia last night they got bk to me with this messege and it workis so do this
• Turn the phone off.
• Remove the battery, SIM card and memory card for at least 15 minutes.
• Reassemble and turn the phone on.
Then, monitor the functionality of your phone.
If your phone is not responding, try to recover the device by formatting it manually:
• Press and hold these keys: [3], call and [*].
• Press the power button for 1 second.
• Continue to hold [3], call and [*] until you hear the start-up tone.
and it works i can use my n95 agen now so give it a tri
Jan 29, 2008 | Nokia N95 Cellular Phone
N95 unlocking
When you have the unlocking codes for your N95
1. turn phone off
2.take the battery off and the sim card out.
3. putt battery back in
4. switch phone on
5. enter unlock code using non predictive text.
Nov 12, 2007 | Nokia N95 Cellular Phone
Nokia N95 continue restarting problem
take a back up... do normal reset of ur fone...and run any antivirus software in ur fone....transfer ur data thru data cable....
Sep 05, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
65 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
