Question about Samsung DVDR120 DVD Recorder
Samsung DVDR122 My problem is that it keeps turning itself on, ejecting the disc in the recorder, then closing and turning the power back off. It does this 3 - 4 times, and then will eject and just leave the disc open. Have tried unplugging etc, but nothing works. Help please as this is doing my head in!!
  • Anonymous Feb 16, 2008
    Cuando trato de grabar el DVD-r120 aparece el mensaje de error 512 o 508. Que puede ser?
    Gracias
  • Anonymous Mar 05, 2008
    disc cannot be played or recorded on. worked perfectly for a couple of months
I have exactly the same problem as above
Posted on Mar 01, 2008
Samsumg bluray e6500 keep ejecting
Reduce any lights or reflections that can be detected by the "remote eye" on the player. Increase the distance to other electrical equipment.
Mar 30, 2014 | Samsung BD-E6500 3D BluRay Player No...
Tip
Force Eject
If a disc gets stuck in the recorder, there a few steps to try before the problem becomes service-related:
1. Power the unit off (so it shows the clock), then simply press the Open/Close button. The unit should power on and attempt to eject the disc.
2. If the above doesn't work - power it off again, then press and hold the STOP and CH UP button on the recorder itself together and hold them down until the unit powers up. This is called a force eject. If this doesn't work (usually if it's not going to work the recorder will simply come on momentarily then loop back into "bye" and go back to the clock), there is one last method to try.
3. Unplug the unit for 30 seconds. Press and hold the same buttons as above as you plug it in. After it performs the self-check "ooooo" across the screen it should do the force eject. If not, the unit requires service to be repaired and possibly the drive replaced.
on Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have an RC100H that keeps opening the DVD/CD tray as if it does not read the disc. Even if I have no disc in it the tray opns and stops. The only way to keep the DVD Tray closed it to hit the close...
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 21, 2011 | LG RC199H DVD Recorder/VCR
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Unable to eject disc using open/close buttons
if your not able to eject the disc using the open close button then try to user a paper clip push the clip in the small paper clip hole provided in your player it'll eject the tray..
if this often happens check with new disc if it still happens try to contact a the samsung for a authorized repair..
hope this was helpful
Oct 02, 2010 | Samsung DVD-V6800 DVD Recorder/VCR
I can't record with my DVD player on 1x-16x DVDs
This unit is too old and too basic to handle 16x speed. However, there is a firmware update for this model DVD/VCR to record on 8x.
All you have to do is call the toll-free number in your manual and request it. They will send you an update disc.
Here is the basic procedure after you receive the update disc:
1. Turn on your TV and your combo unit. The tray should be closed. The unit must be in DVD mode.
2. Quickly press the sequence CM Skip, 6, 5, 4 (This will switch it into firmware update mode. The tray will eject automatically.)
3. Insert the disc and push the tray back in.
4. The update will begin. It will take approx. 2-3 minutes. It will tell you when it is complete and eject the tray.
5. When it is done, remove the disc, but DO NOT close the tray. It will go back in later. Turn the power off.
6. Wait a few minutes and when the tray goes back in wait about another 10 seconds and then you may turn the unit back on.
Firmware update procedure is now completed.
Sep 11, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Disc won't eject & stops working
your disc tray is jamming on an intermittent fault and when it does work it is recording each time the eject botton is being pressed so when your watching movies or playing games it tries to eject the disc tray and causes an automatic shutdown it will definately neet proffesionally repaired and should cost about 30-40 pounds and get a guarantee with it bacause these faults can come back to haunt you.
Oct 06, 2008 | Microsoft Xbox 360 Console
Have a phillips DVDR model#3455H.Inserted dvdrw disc recorded with videos recorded on it in my computer. Disc works fine in my pioneer dvdr but when I put it in the phillips it will not load and it will...
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
Apr 03, 2008 | Televison & Video
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Samsung DVDR120 DVD Recorder Logo
124 people viewed this question
Jerry Greenberg
Jerry Greenberg
