Question about Maytag PYE2300AY Electric Dryer
Drum is off balance - Maytag PYE2300AY Electric Dryer
    President:
  • 1,304 Answers
Check your front glides
Posted on Oct 03, 2009
It shakes excessively on spin cycle, machine is level, it does it on every load, it is beginning to tear up door seal
It shakes when off balance. Your wash load may be balanced but the drum may not be. This could be down to the drum bearing or the "spider" that holds the drum in place. If one of the arms is broken it will spin off balance.
Oct 26, 2015 | Washing Machines
Error code warning my load is out of balance
If the drum spin noise is loud your bearings need replacing.
If the bowl(drum)goes out of balance with nothing in it your bowl needs to be replaced.
Sep 03, 2012 | Fisher and Paykel Washing Machines
1998 Toyota Siennia rear end vibration at 55 and up. Installed new tires and new brake drums and shoes.Could the new drums come out of balance?
With significant vibration around 60 m.p.h., it is far more likely that the new tires are out of balance. Even if they were balanced at installation, sometimes the balance weights simply fall off. Although it is possible that the drums were not correctly manufactured, it is far less likely that would be the cause of the vibration.
Jul 02, 2011 | Toyota Sienna Cars & Trucks
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Drum is off balance clothes get stuck in between drum and front of dryer and they get burn marks on them (kelvinator dryer)
there is a felt liner that is on the front of the drum it can be reglued with hi temp glue from a hardware store. and there are at least two wheels that the drum runs on they are on the bottom front of the drum that balances the drum. good luck
Aug 10, 2010 | Dryers
Excessive drum vibration
Yes, look into trading in the Kenmore for one of only two manufacturers that employ a dynamic balance system built into the washer drum. Samsung and LG both use this dynamic balance system that balances the load while it is in motion. They also use a vibration sensing system to modify the time and speed of the spin cycles to minimize any vibration that might still be present. LG has this available on only their upper level models while Samsung's VRT is available on most all models. I believe that both of these manufacturer's are available from Sears.
Oct 03, 2009 | Kenmore 43142 Front Load Washer
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
With only 1 item in Drum my new Bosch WAE24363 will not perform a spin cycle, yet adding more item into the drum then the machine will perform a full spin cycle. Why will the machine only do a full spin...
most modern machines have an out of balance detector to prevent the machine being damaged with a badly balanced load.
with a single item in drum, load will not balance and out of balance detector comes into action and prevents spin
Sep 09, 2008 | Bosch Washing Machines
Drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Maytag PYE2300AY Electric Dryer Logo
133 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
