Brother HL-4040CDN Laser Printer display reads OUT OF MEMORY. Can I clear the memory in the printer, if so how do I do so?
  • 161 Answers
Should be under maintance.
Posted on Sep 26, 2009
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
  • 13433 Answers
SOURCE: where can I get brother hl-2030 LASER PRINTER DRIVER
Hey,
The brother drivers and software require for the machine is available at
http://www.brother.com/E-ftp/info/index.html
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 05, 2009
  • 4 Answers
SOURCE: Re-attach fuser cover on Brother HL-4040cn
I had the exact problem. Had to order a new fuser unit, as this is not a serviceable part. But I took pictures for future reference. CLICK HERE.
Service Manual I found online for free download
Posted on Sep 23, 2009
callonafo
  • 174 Answers
SOURCE: Service manual for a Brother HL-6050DN Laser Printer
You can get the Service Manual for your printer by clicking on the Link below.
http://www.smpcshop.com/HL-6050-HL-6050D-HL-6050DN-p-4010.html
The price of $9.95. Thanks
Posted on Oct 19, 2009
SOURCE: Model HL-4040CDN, told me to change magenta toner
Have the same problem, can't find the solution. Filed a complaint on the brother website feedback link, hopefully they will resolve if more people post problems with toner cartridge changes
Posted on Dec 16, 2009
How do I clear the memory from my Brother HL-1440 printer?
Printer memory will clear if you simply unplug it from the wall. More likely, the old document was in your computer's disk, and you can control what prints from there.
Sep 11, 2014 | Brother HL-1440 Laser Printer
What do I do when my Brother printer 4040cdn has the message "drum end soon"? It has ink cartridges that are not empty. When they need to be replaced there is a flashing light.
The drum is replaceable.
You can continue to use the printer but over time the print quality will degrade. At that point the only option is replacing the drum.
Brother claims the average drum life spans about 17,000 pages.
I hope this helps.
May 07, 2014 | PrintCountry Brother HL 4040CDW Laser...
Brother HL-4040CDN printer colors are off, tend to be pink
There could be a number of causes for the problems your describing, but one of the most common causes of discoloration and issues with toner is a faulty ribbon sensor. A broken sensor will be unable to accurately read the ribbon and apply the correct color. I hope this helps
Sep 02, 2012 | Brother HL-4040cdn Color Laser Printer...
I have an HL-4040CDN Brother printer that prints too red. We just purchased it and need how to fix this problem. It also prints colored text too light.
Many people are having problems with this machine. If you are dissatisfied with the quality I would return it and try something else. Your most economical solution is going to be a factory refurbished (with warranty) HP color laserjet. Staples usually has some good deals.
Jan 18, 2010 | Brother HL 1440 Laser Printer
It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
Nov 11, 2009 | Brother HL 1440 Laser Printer
Nov 10, 2009 | Brother HL-4040CN Laser Printer
Brother hl 1440 laser printer, print job stuck in que.
Try to stop the print spool and restart it. This should clear any jobs that's in your pc. As for the printer ususally if you shut it down for about 30 sec, it should clear the printer memory.
hope this helps.
Mar 27, 2009 | Brother HL 1440 Laser Printer
Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
Dec 16, 2008 | Brother HL-4040CN Laser Printer
508 people viewed this question
jasbo
jasbo
