Question about Lexmark X2350 All-In-One InkJet Printer
Not printing Hi my printer is not printing. The light just blinks and the cartridge just zooms from one side to the other. It sounds like it is slamming against the sides. I looked insides and found a strip of some sort that is not hooked up to anything. It is an opaque black strip that is about 24" long and has an opening at each end of it with arrows. Please help.
  • melly75 Dec 17, 2007
    It is the encoder strip
  • melly75 Dec 18, 2007
    The printer was working before and is the default printer. The computer settings for the printer is fine, it's the printer that's an issue. The encoder strip has come out and I need instructions how to insert it again. Thank you.
Go to printers & faxs, make the printer default.
Posted on Dec 17, 2007
Print cartridge light is blinking
For the Deskjet 940 open the lid to see which cartridge the printer is compalining about. Clean the carriage and cartridge electrical contacts with a cotton swab moistened with water and verify that that the correct cartridges are installed (45 and 78). Then clean the contacts on the cartridge and the printer, also try these steps here.
Hope this helps, Thanks for using fixya!
Nov 04, 2011 | HP DeskJet 1220c InkJet Printer
Cartridge light blinks
Try cleaning the print head first in the software options on the printer and then lightly with a qtip and alcohol or electronics cleaner. The ink jets sometimes dry up and cause the nozzels to get plugged.
Sep 02, 2009 | HP DeskJet 845c Printer
Check Print Cartridge
hi have you tried taking the printer cover off and looking at the sponges in the back it sound hard but its not . if they are soaking you need the washing gloves on and take the sponges out to clean them under the cold tap then put them back in now do a google search for a site called for the software that you download to turn off your blinking lights this sight worked for me good luck
Jun 05, 2009 | HP PSC 1315 All-In-One InkJet Printer
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
Printer will not print. power light and feed light blink on & off
the power and feed lights blinking is the indicator for a (printer cartridge has stalled) problem sounds like there is a cartrage mis-installed or a peice has broken off and is tripping the sensor. In the first part of you problem you said you resolved a carteage problem that might lend a clue depending on what you actually did to resolve that issue could be the cover that you have to peel off when you install a cartridge and a peice got torn off good luck
Mar 26, 2009 | Lexmark Color JetPrinter Z32 InkJet
All lights keep blinking!tried unplugging and reinstalling.Dead?
If the Resume c00121686.jpg light continues to blink and the print cartridge cradle does not move to the right side of the printer, try these solutions:
  • Remove and reinstall the print cartridges. Verify that the print cartridges are in the print cartridge cradle before pushing them forward into position.
  • Verify that no obstruction prevents the print cartridge cradle from moving freely on the rod.
  • Verify that the vinyl tape has been removed from each of the print cartridges.
If the problem persists, contact HP Customer Care.
Jan 14, 2009 | HP Photosmart C3180 All-In-One InkJet...
Lexmark 2400 has message saying clear carrier then press start
Good day Sir, Please check the power switch light if blinking.
  • power light blinking slow - printer is out of paper.
  • power light blinking fast - there is paper jam in paper.
  • once, pauses and blinks again - raise the scanner unit, and remove any objects blocking the path of the printer cartridge carrier. Or the print cartridge is missing/ not installed properly. Or the printer cartridge is not the correct type for the printer.
Have a nice day.
Nov 22, 2008 | Lexmark X1240 All-In-One InkJet Printer
Inserted new cartridge (#96 will not register that the
Hi felinemcmeow, you need to remove the cartridges from the printer,
  1. Open the printer cover
  2. Wait until the carriage moves to the right side of the printer and is idle and silent
  3. Press down lightly on top of the cartridge latch
  4. Pull out the bottom of the latch to unlock it
  5. Slide the cartridge out
  6. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer, and then slide the print cartridge into the carriage
  • Install the tri-color cartridge on the left side of the carriage
  • And install the black cartridge on the right side
Once completed lower the cover and the printer is ready.
If this does not resolve the problem please come back so we can try another step.
Nov 12, 2008 | HP Deskjet 6940 InkJet Printer
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
