Question about Canon FAX L-120 Plain Paper Laser
Loading paper Hello Hope you can help - everytime we tput new paper in the fax machine, it still says "load paper" and we just press any or all sort of buttons then it seems to rectify itself - can you help on this one. Many thanks Regards Jude
Still doesnt work......grrrrrr
Posted on Feb 11, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
There should be a sensor in the tray, that tells it when it has or is out of paper. Is it there is it OK?
Is the paper and size OK?
My 1st impression is the sensor that is in the tray.
here is the manual in just in case, try the trouble shoothing section
http://www.retrevo.com/s/canon+l120+manual
Posted on Dec 18, 2007
When sending fax on canon pixma MX350 i get a NG error REPORT what does this mean
Hi There!
Comm Error will show on the display if there is an issue with the phone line like an interference or it's not connected directly to the wall jack.
What you can do is check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then press start.
Hope this helps.
Vikroks
Mar 29, 2011 | Brother IntelliFAX 560 Plain Paper Fax
Everytime I am sending a fax i get the common error 20 02
Comm Error will show on the display if there is an issue on phoneline that were using.
First please check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then hit start.
Hope this helps.
Mar 29, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
Having problems with our 7820N fax printer. Paper is getting stuck almost everytime we copy or receive a fax. It usually is in the back of the machine and the paper needs to be pulled out and then is...
Hi!
It is best to have someone check your printer for blocks or anything that may have caused the paper getting stuck. Another thing to do is to fan the stack of paper that you load. Do not load it straight away. Sometimes paper get stuck to each other and cause some loading issues.
Feb 11, 2011 | Brother MFC-7820N Printer
Fax
Often, this type of problem is caused by the paper sensor which is nothing but a small switch activated with the presence of the paper(s) pressing on it, It would look like a small tab/lever that would move (to activate the switch) by the paper pushing against it. You would have to inspect this lever/switch and determine if it would move freely. It is very rare for the actual switch to go bad, often it would be just the tab/lever not depressing deep enough to engage said switch.
Hope that this beof initial idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 02, 2008 | HP 1010 Plain Paper Inkjet Fax
Paper won't load.
All you need to do is load paper in upright tray and then press the red stop button that is situated to the right of the green button and any fax that is waiting in the memory will print out. Hope it helps.
May 06, 2008 | Office Equipment & Supplies
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
Fax in memory
Either load paper or ink cartridge. If it is paper I think you will need to either press the start button or the stop button then it should start printing automatically.
If it is the ink cartridge after you have installed a new one then it should start printing.
Hope this is of some help to you
Thanks J
Nov 06, 2007 | Brother IntelliFAX 560 Plain Paper Fax
Fax Machine Jams Everytime I Try to Load Paper...
Is it jamming at the document feeder, or in the blank paper tray? You may need to clean the feed rollers. Use a lint-free cloth (not paper) and some alcohol.
Dec 27, 2006 | Sharp UX-B20 Plain Paper Inkjet Fax
Canon FAX L-120 Plain Paper Laser Logo
old marine
old marine
