Question about Black & Decker Drills
Cannot remove battery from charger. what am I doing wrong?
    President:
  • 1,714 Answers
The battery is either in the charger wrong, or it 'swelled' during charging. Is it hot? Pull hard and it will come out.
Posted on Sep 26, 2009
Battery and or charger won't work. Charged a full 18 hrs. Help
Possible suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
Nov 27, 2015 | Motorcycles
Well Ted I'm the one with the battery phone problem, Johnny Rebel said it was the wrong battery. Anyways I take the battery out the screen comes on I put it back in then it goes blank.
you must have the battery charger connected when you remove the battery otherwise there would be no power to light up the screen
units do not have residual power supply
it is possible that it is the battery ( faulty--wrong type) or there is a problem in the charger to battery circuit that is creating a back current that is in effect switching the unit off
I suggest a trip to a service centre to have the fault diagnosed and a quote for the repair.
Jun 29, 2015 | Cell Phones
Persario/HP charger scam
Remove the battery before you plug in the charger/adapter and see what it will do. It can't recognize a battery mode if there is no battery. Maybe the charger you are using is not appropriate: different voltage, wrong polarity, the tip is not in contact with the plug terminals, or the circuit is not closed to allow the passage of current.
Rocketfish, Targus , and a few others, manufacture universal chargers that work with may laptop makes and models.
Mar 30, 2014 | HP Compaq Presario CQ60-249US Notebook
Recharge battery Cadillac Deville 2005
You do not need to remove the battery to charge the battery. When you connect the charger you MUST be careful to connect the charger's positive lead to the positive terminal to the battery and the negative lead to the negative lead to the battery before you turn on the battery charger. Connecting the charger leads the wrong way around most likely damage the vehicle's electronics.
When you finish charging the battery turn off the charger before you disconnect the charger leads. This will prevent arcing between the leads and the battery.
Jan 14, 2012 | 2005 Cadillac Deville
I already replaced my charger once. This is the second time it just wont charge my laptop and it hasn't even been a year since I replaced the last one. What is wrong?
guess the problem is with your laptop battery....chargers normaly dont crack soon.....
charging the battery....is not OK
to sort out the issue
do this...
1 remove the battery from the battery bay....(hope u know how to do that)
2 now connect the adaptor and check if the notebook works....(without the battery in the bay)
3 now remove the adpator and install the battery...check if it now works with just the battery....
4 now connect the adpator to notrbook with the battery in it's bay...start the notebook.....and let it work for some 3 - 5 hrs
5 remove the adaptor...check if the battery immediatly takes over...if not then battery is the issue
Feb 17, 2011 | Compaq Presario CQ60215DX Laptop Charger...
Cell phone took a ****
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Apr 15, 2010 | Motorola Mobility Clutch i465 Cell Phone
Battery
change the phone memory
Apr 02, 2010 | LG Vu CU920 Cellular Phone
Not charging
No, there is nothing wrong with your charger. Its a voltage irregularity problem. Once it happens next time, remove the charger, remove the battery, put the battery back and try again.
I use HP 530, and I experience the same problem once in while but not every time.
Good luck.
Mar 17, 2010 | HP Pavilion g60-440US Notebook
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Drills Logo
27 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
