Question about CDA Washing Machines
Need cda ci993 washer dryer manual, can anyone help?
5 Suggested Answers
  • 6277 Answers
SOURCE: Hi, I have a CDA
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Posted on Mar 26, 2011
  • 6277 Answers
SOURCE: Water is not draining after
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up on the rating.
Thanks and good luck!
John C
Posted on Apr 14, 2011
  • 6277 Answers
SOURCE: Trying to find instruction manual
I'm sorry if you are the person who has previously been unsuccessful finding a CDA washer manual on the web because this solution will not assist you ;-0(
However if you are NOT that person you will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
John C.
Posted on May 01, 2011
Testimonial: "Thank you. Will try your suggestion"
emissionwiz
  • 78936 Answers
SOURCE: I need an instruction manual
Hello
If you go to the web link below you will find a pdf file format user manual (installation use and maintenance) for the CDA C1993 Washer dryer. Cheers!
http://www.cda.eu/downloads/ci970_im.pdf
If the link doesn't work copy and paste the address into the address window of your web browser.
Posted on Jun 24, 2011
I have a CDA ci992 with no instruction manual. I cannot get it to JUST dry. I just need to know which setting to put it on. Any chance you can help? I've tried searching for an instruction manual...
Lisa set the time required on the Drying time control right hand side for high temperature up to 130 mins max and left hand side for low temperature up to 90 mins max. Now set the washer timed dial to the drying emblem (3 vertical wavy lines) next to position 8, then finally you need to push in all 4 control buttons on the left of the thermostat. It should now work according to my wife. Dave
Sep 02, 2011 | CDA CI592 Front Load All-in-One Washer /...
Trying to find instruction manual for a CDA Ci 592 washer dryer
John C.
May 01, 2011 | CDA CI592 Front Load All-in-One Washer /...
Hi, I have a CDA I992 washer dryer in my flat but no instruction manual. Do you Know where I could get one from?
Good luck,
John C.
Mar 26, 2011 | CDA Washing Machines
User manual for cda CI992
Got a cda CI992 with my apartment no instruction manual
can i have one please :-)
Jul 23, 2009 | CDA CI592 Front Load All-in-One Washer /...
CDA C/392
you should e-mail service@cda.eu or contact them through their site; http://www.cda-europe.com/docs/CCD_Home.htm Hope this helps :)
Jun 25, 2007 | CDA CI392 Front Load Washer
Washing Machines Logo
379 people viewed this question
Top CDA Washing Machines Experts
NOEL
NOEL
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
