Question about Weber Q Grill
How to Clean The OUTSIDE of my Weber Q BBQ?
I am interested in knowing how to go about cleaning the outside of my Weber Q BBQ. The cream-coloured cast iron casing has turned brown at either end - due I expect to the heat of the BBQ.
Maybe it can't be cleaned, but I would be interested to know what to do, if indeed it can be. Can someone recommend what I should use as a cleaner? I have tried Fantastic, Vim, bleach, even Ajax, but the stain stays virtually unchanged - even when rubbing it with a cloth, brush, SOS pads or fine steel wool.
Thanks,
Ian
  • Weber Master
  • 3,087 Answers
CLR is good .
Posted on May 13, 2017
  • 157 Answers
SOURCE: weber gas bbq
Hello stevie66, disconnect the gas tank, carefully remove the burner element (the thing with the small holes) and soak it in a bowl of vinegar overnight. Remove and shack the excess out, remount and connect the gas. Open the gas line about 1/4 turn and CAREFULLY LIGHT. Please E-Mail the results. Thank you.
Posted on Nov 12, 2008
  • 46 Answers
SOURCE: bbq regulator
should be able to get some help at your local hardware or home & garden store!
Posted on May 31, 2009
SOURCE: Converting Weber Genesis Silver B from LP to Natural Gas
Hello...I have the same grill and want to do the same conversion...From my research, you need to drill out the three orifices with a size #53 wire gauge drill bit. ( this resizes each orifice to 12000 BTU's each, which the grill is rated at 36000 BTU's).Then remove the existing hose and regulator. Replace the hose with a Quick disconnect compression fitted hose. The NG supply needs to have a pressure regulator installed, with a shutoff and quick disconnect fitting installed. Connect the hoes from the grill to the supply, and fire it up...THIS IS WHAT I INTEND ON DOING TO MY GRILL,BUT YOU DO THIS AT YOUR OWN RISK>>>
Posted on Jun 29, 2009
  • 60 Answers
SOURCE: How to Clean Weber Gas Grill Lid
you can only use oven cleaner on enameled hood not on the cast painted parts like the body and sides of the hood those you can scrape and vaccum or brush
Posted on Aug 09, 2009
SOURCE: should there be fake coals in my gas weber bbq
Get rid of the fake coals they will only collect grease and cause a fire.
Posted on Aug 17, 2009
My Bar B Chef grill grates are totally rusted. Are stainless steel grates better or should I stick with cast iron?
I prefer cast iron. Cast iron heats more evenly and retains temperature better. If they are falling apart from rust, junk them. If they just have surface rust and no holes, all you have to do is brush them with a steel brush at high heat. Wipe them off with a wet rag and then rub it with an onion to provide a teflon layer. if it is really heavy rust, spray oven cleaner on them and hose off. After use or for storage, clean them and then wipe them down with a cooking oil soaked rag. The oil will reduce rust build up.
Feb 28, 2015 | Grilling
Rocks have turned brown - is there a cleaning solution to remove the build-up?
outside adornments that turn colour do so from the water used. It is normally a higher than normal iron content in the water or surrounding soil. Try spraying the rocks with CLR and leaving for a time to work
Dec 14, 2014 | Cars & Trucks
Weber silver b. cooking grate has rusted. what is it made of. terrible!
Steel with either a black porcellian finish or a chrome finish. Depends on the model.
Stainless Steel or Cast Iron is my personal favorite. It wears extremely well and is easy to clean.
Jun 22, 2011 | Weber Genesis Silver B Grill
The rubber flexable hose for my Weber baby Q bbq is leaking. I have demantled it , but where can i buy a new hose? Thanks Andrew
Take it to your local propane co and have them make up a new hose for you. Be sure to bring the hose and regulator, or just bring the whole grill with you, so they can see what you have. Some bbq hose ends don't have regular swivel brass fittings on them anymore, bit instead use a hose barb adapter to reattach directly to the grill. So I'd suggest bring it all just in case you have one of those kinds. Douglas
Jun 15, 2010 | Weber Baby Q Grill
Weber Silver BBQ has 3 burners only 1 has normal flame.
you may have to remove the burners and clean the inside of them. they could have insect webs inside preventing the flow of gas. hope this helps. also, try opening the tank really slowly.
Oct 12, 2009 | Weber Grilling
Should there be fake coals in my gas weber bbq
Jun 29, 2009 | Weber Genesis Silver B Grill
Weber Q Grill Logo
359 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
