Question about Kenmore Ovens
Kenmore double oven - model# 7947773403 - code PF is on and oven won't turn on
    President:
  • 1,714 Answers
Pf is 'power failure'. Have you checked breaker? Turn breaker off and back on to reset.
Posted on Sep 26, 2009
My double oven Kenmore Model 790.48762900 had a PF code on the screen and now it is completely black. No power, nothing. What do I need to do?
Check the manual for the significance of that code and do what it tells you - maybe there is a reset necessary. If there is no positive result, then you will have to get unit services.
Aug 24, 2015 | Ovens
My oven doesnot start as soon as i press the bake it shuts off and says PF
See if any of these fits the picture. Notice the last one "caught fire" http://www.fixya.com/tags/kenmore_oven_pf_code
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/8392-kenmore-oven-throwing-pf-codes.html
Some sage advice here.
Mar 15, 2015 | Kenmore Ovens
Superba model: YKEBS208DB3 electric sove shows code PF. what does this mean?
PF stands for power failure, just hit cancel and reset clock.
Good Luck, I hope this helped.
Nov 27, 2013 | KitchenAid Architect Series KEMC308KSS...
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore double oven flashing "door locked"
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Go to PF when there is none
wshort, As long as you are sure the circuit to the oven is not the problem,such as drop in voltage, here are a couple of suggestions. Number one is that the electronic parts for this model have a five year warranty on them and you may want to call for factory service. Sometimes the connections on the main control board become loose or corroded. Try reseating them and see if the problem stops. If not I would suspect the control board power transformer behind the control board. There are two transformers, one for lights the other for the control board. The control board transformer should have the red and blue wires while the light transformer will have the black and white. The voltage could be dropping out here. Make sure that the wires to the oven terminal block are not loose or burnt. Since you are not receiving any error codes except for PF, Im not suspecting the board itself. Catriver...post back.
Dec 26, 2006 | KitchenAid KEBC278 Electric Double Oven
Ovens Logo
232 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
