Question about GE Spacemaker JVM1640SJ Microwave Oven
Oven will not heat up?
Oven will not best up, just stays cold, wlll not cook?
  • 6,784 Answers
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Sep 26, 2009
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
The microwave looks like it is working but no matter what I do there is no heat. I put in a cup of coffee and hit the minute button. It turned on and goes around but the coffee is cold. So I tried...
HELLO.
Below is the solution on how to make our microwave heat food.
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thanks.
    Sep 20, 2011 | Microwave Ovens
    Everything functions on microwave, it just doesn't cook. After pressing cook, the light comes one, the time runs down, just no cooking.
    It's possible the magnetron tube, the microwave source, has failed. They can go bad in a couple of ways, and one will cause that symptom (the other causes a loud humming when the oven is trying to cook, but no heat). Other possible causes are bad solder connections or loose terminals on the control board or door switches, or parts in the magnetron's power supply that have failed. If the oven is over 5 years old and has been used often, it's very likely to be the magnetron.
    This kind of problem usually needs to be diagnosed while the oven is plugged in and operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES THAT CAN KILL YOU, so troubleshooting and repair is best left to professionals with the tools and experience to do it safely.
    If you want to keep this oven, let a professional check it over and give an estimate. Then you can weigh that against the cost of a new oven; sometimes it's more economical just to replace it.
    Jun 12, 2011 | Frigidaire FMV152K Microwave Oven
    Our emerson microwave will not make anything hot.put in time for something to cook it runs fine but it will not make the food hot HELP!!!!! the sides and top and bottom of microwave are warm but food is...
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    Sep 14, 2010 | Emerson Microwave Ovens
    Microoven model 860A is not getting heated
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Basic Microwave Oven TroubleshootingTips
    heatman101p][p[]p
    Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
    Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
    This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
    Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
    GE Spacemaker JVM1640SJ Microwave Oven Logo
    49 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    D. E. Hev
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
