Question about GE Profile Energy Star PSC25MGS Side by Side Refrigerator
Water Drips from Ice Bucket
Periodically the freezer seems to go into a defrost mode and melts all the ice in the ice bucket. Later it will refreeze. If I do not keep a bucket under the ice bucket I end up with ice cicles hanging down through the freezer. I have been told this is the fan. But why does it seem to correct itself later. Problem occurs about every 2-3 days.
GE Profile Model: PSC25MGTA
  • GE Master
  • 19,396 Answers
As far as I know the fan does not normally cause this kind of defrost, but some of this fridges use a complicate temperature control system and you never know.
If the problem is restricted to the icemaker, the only way the ice can melt is if the heating release system starts heating up because of a contact. The problem is that this icemaker does not have evap system inside icemaker. Contrarily to majority of built in icemakers, this model uses an auger based mechanical release system. If problem is restricted to icemaker, then I would replace the whole icemaker assembly: ICEMAKER ASM (MECH ICEMAKER ASM).
If the whole unit is defrosting, then the first part to test is instead the defrost thermostat DEFROST THERMOSTAT (THERMOSTAT DEF). Defrost thermostat can be tested using a multimeter. To test, cut thermostat contacts and read impedance with tester set at Rx1 to read impedance. The thermostat must return low or 0 impedance at low temp, and infinity when limit temperature is reached. Also check for any weird thing in the defrost system, also temp sensors should be tested.
This fridge has also an humidity control, when dampness is eccessive, the control board will start fans. That can also be causing the problem.
A technician on site will probably test the defrost system, and then replace the control board (MAINBOARD KIT D/EVAP (KIT MAIN BOARD SERVICE)
Try first disconnecting fridge from power and allowing a complete defrost overnight. This can fix a jammed sensor, and will reset the electronic control board.
If that does not work, check the warrant status, repairing this fridge it is quite easy to replace wrong part, since the fridge is working, a slightly defective elecronic control will be impossible to test. And repairing under warranty will cover any part needed. If warranty is expired, call manufacturer and discuss purchase of a five years warranty extension.
To proceed with the repair, test the defrost system, check wiring and temp sensors, then replace the control board, that is most likely the problem.
Posted on Sep 26, 2009
Samsung double door model SR-L709EVSS - Freezer is chilled but does not make ice. Ice/frost packs on the wall of the freezer. As soon as I open the freezer door the temp defaults again.
Hi.. this can be caused by a number of things, however, that packed ice on the wall leads me to think this is a frozen solenoid on the water intake..
The most difficult thing about the fix, is where to put the contents of your freezer for overnight.. check with your neighbours, or get a large cool box.
the fix is to simply defrost the freezer THOROUGHLY.. it cannot be rushed with a scraper as the ice is within a closed valve and possibly backing up the water pipe by an inch or so.. make sure that the ice bucket fill wire is up, so that it does not try and make ice when you let it thaw properly overnight, dry it thoroughly and then set the freezer temperature to it's warmest setting for a few hours, then a little cooler, and so on, until you get to the desired temperature.. then drop the ice gauge wire to trigger ice making.. check back in a few hours to see if any has been produced
When you return the food, please pre-sort it, into shopping bags, each bag representing a shelf so you can fill the freezer swiftly.. then the ice that's made won't melt slightly, and then refreeze, sticking it to the ice bucket.
Apr 23, 2017 | Samsung Refrigerators
Freezer temp flashing post removal of ice bucket components - is this why?
Possibly because of ice build-up under ice bucket, a common occurrence. It needs to be removed and wiped off periodically. And the ice sometimes makes it difficult to remove the ice bucket, so you may need to use some warm (not hot) water in a spray bottle (squirt warm water under the seam at bottom of bucket) to get it loose. Of course, this is all assuming the bucket is the type attached to the door.
Dec 15, 2014 | Refrigerators
Will not dispense ice
commonly what you will find on that model is the main control board on the back of the unit is the source of your issue, it begins like a computer virus where the unit will render the water in the door feature useless, next goes the ice delivery sys, then the unit does not defrost properly causing cooling issues. But before running out and getting a new control board go by this check list first: 1) make sure your ice bucket is properly seeded, 2) make sure the ice in the bottom of the bucket is not melted together if so empty good ice in seperate container and put back in freezer quickly to avoid melting then run hot water in ice bucket to melt remaining bad ice afterwards completely dry ice bucket and put good ice back in and see if it works properly, 3) make sure the auger mtr is not seized due to door being left open and humidity freezing in mtr gear.
Apr 16, 2012 | GE Refrigerators
I have a Kenmore top freezer. Every few days the freezer will get warm enough to cause the ice in the ice maker bucket to melt a little and then it will refreeze into a big block of ice when the...
Hi, It is sticking in the defrost mode...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Kenmore Top Freezer Refrigerator
I cannot get the ice bucket out of the door. It has always been very difficult to remove unless it was just after I emptied the bucket and let it completely dry out before returning it to the door. I...
its just partially defrosted, ice chunks are up inside and through the unit, keep using the hair dryer,, also , once its defrosted completely, Look for a small leak , thats whats causing your problem in the first place
Jul 16, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
HOT POINT FRIDGE - FREEZER DRIPS WATER
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Jul 12, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water is running from the back of the freezer compartment and periodically seems to defrost and run out of the door and flood the floor Can you hepl
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 15, 2009 | Fisher and Paykel Active Smart® E522BR...
The ice in my ice maker bucket is melting and refreezing into a solid mass. I just looked at a recently made cube and it still has liquid in the center.
Yours has a 215846602 Defrost Timer, Located inside the fresh food compartment. I believe that it's sticking in defrost and you possibly need a new defrost timer.
Here is a photo location of the timer # 23 is the timer. I want you to turn the timer until the refrigerator compressor stops. Time it for about 25 minutes and the refrigerator should restart. If not then it's sticking in defrost so again turn clockwise slowly until the compressor restarts. That is possibly what is causing the melting and refreezing. Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
Aug 19, 2009 | Frigidaire FRT18S6AQ Top Freezer...
Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Jan 20, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Marine ice maker problem
Mine has been doing this for years. You can check if the door gasket is good and sealing well. If not you can oder one and easily replace it yourself. Also, if I did not run my generator when I took a short ride ice inside would start to melt while the unit is off, usually around the case perimeter which would drip down to the bottom under the bucket and then when it was put back on it would refreeze under the bucket like a block and make it impossible to remove. I would sometimes just turn it off, put the ice in a ziplock in my frezzer to save it, let it defrost to get the bucket out and dry up the standing water.
Aug 25, 2007 | U-Line Icemaker
GE Profile Energy Star PSC25MGS Side by Side Refrigerator Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
