Question about Printers & Copiers
Detailes of the Model Ricoh Copier Aficio MP-3350B
Dear Sir/Madam,
i m looking out for the Ricoh make Model Aficio MP-3350B please help me to source out the sameor get me the specificationes of the same.
txs & with very best reg
taral dave
  • 287 Answers
SOURCE: ricoh aficio mp 2510
Hello e3tech, faatmaan has given you some valuable and accurate information. I would like to offer you some additional information that may help. i am not sure to what degree you have technical experience regarding problems as deep as you are experiencing. I just want to try to help you starting with the basics. We can get the proton accelerator out as a last resort. :-) In the event you have not tried to reset the code (which you can in the event that this code was a temporary condition or erroneous to start with) let me walk you thru the process of resetting the code and lets see if the copier can recover without going into the ugly (but prehaps necessary) and expensive stuff. Again I am just trying to help and this is the first thing anyone should do. We need to enter service mode, usually accessed by the expensive on site technician but you can handle it. This is the first thing I would do if I was onsite. I have been working on copiers for 20 years, which may merely mean I have been on a reign of terroe for that long, screwing everything up! LOL .Ok in order to enter sevice mode on your machine you will need to press the yellow button marked "clear modes" then then numbers 1-0-7 in slow but firm sequence, and the the orange stop clear button and hold IT down tull the screen changes and you will hear a beep. Once again......Clear modes,then 1>0>7 (in sequence) then hold down the orange stop/clear button till the screen changes and you hear a beep. (note....the beep is not guaranteed as it can be turen off prior to what we are doing but you will see the screen change). the new screen may say a number of things but for sure it will have a block named copier. Press that block which will bring up another new screen with all kinds of stuff that you need not be concerned with.The fact that you are at this screen is the cool thing. At this point, turn the main power swith off....!!!!!! THE ONE NEXT TO YOUR LEFT KNEE!!!!!! not the one on the op panel. Unplugging the copier will do the same if you are unsure.The point is to totally de-energize the copier. Turn the copier back on, and this point it will know that some one who knows what they are doing it attempting to help it recover andthe copier will wake up witha new outlook on life and will try to successfully restart back to normal. Without the steps we just went through the copier would have not went through the servicr mode process required foe it to truly have a chance to recover. When you turn it back on, the copier will look at all the critical sub systems it monitors before it feels comfortable to say "READY". In this case the errer code has to do with the very high temperature area called the fuser. As you probably understand, the manufacturer of the copier has designed the copier to keep close tabs on this area as to not burn down your building. So id there is any oddity in this area the machine throws a temper tantrum. So, lets hope hope the machine restarts, and it was a temporary thing , and you wont have to go the route that faatmaan suggested, which again may be absolutely accurate and well detailed. I just thought we could try the reset and hope for the best as it is a genuine and viable option and alot less expensive. I wish you the best. By the way, in the future, ALL error codes you get in the future(and there..are a hell of alot of them) can be reset in the manner I described ealier.This can be a big help for you . It just so happens that this and a few others in the "500" series are less likely to stay reset. I hope I have helped save you alarge wad of cash, but a minimum you are armed with a few valuable tools that may save you buttocks in the future. Take care.................. SPINAL
Posted on Feb 19, 2008
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
SOURCE: Ricoh Aficio MP 4000/5000 PCL 5e
Manufacturer did have Win 9x / NT drivers but withdrew them April 2008 when MS stopped support of those op systems.
I have same problem searching for a driver.
Posted on Mar 09, 2009
  • 227 Answers
SOURCE: How to get into ''service mode'' on Ricoh Aficio MP 2238c
There are MANY things to screw up in SP mode. I agree with sandmanmac. List what you want to accomplish and maybe we can help!!!!
Posted on Mar 28, 2009
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end disrespect intended.
Posted on Apr 11, 2009
  • 41 Answers
SOURCE: Ricoh Aficio MP 6000 copier with error code SC555
there is no sc 555 on those machines only sc 550 and that relates to what is called a fuser web.It does need to be changed but you can reset it by pressing the following in order
1- yellow clear key
2- number 1
3- number 0
4- number 7
5- press and hold down the orange clear/stop key for 5-10 seconds.
the screen changes
select copy sp
select sp 1
scroll down to SP1902 001 and select
reset that value to 0 and select enter
switch machine off and on and that should get you going for now.
Let me know
Posted on May 28, 2009
0 characters
1 Points
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer:
I do find the error code for a different Ricoh model (Aficio 1018).
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
I would like to know how to Fix SC561
If your copier looks anything like the smaller illustration next to the question, there most certainly should be a user's manual in the near vicinity. I'd strongly advise searching it out.
Aug 10, 2014 | Ricoh Aficio Mp 2000 Photocopier Copier
Where i can get ricoh aficio mp 1600 le driver for window 7
You can open and download the driver for free.
You will see this web page. Just choose the model and than choose the OS.
Sep 20, 2011 | Ricoh Aficio MP 1600L Black and White...
Power not on copier aficio 2016
more detailes please tell me what happened
Jan 16, 2011 | Ricoh Aficio 2016 Black and White Copier
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
How do we get this machine (ricoh aficio MP 2000) to duplex print?
There are certain models that can duplex and certain models that can't. Generally if a Ricoh copier can duplex it has a D after the name (like 2018D). If there is no option for duplexing on the screen or the ops panel, that model doesn't support duplexing.
Apr 30, 2010 | Ricoh Aficio MP 2000 Black and White...
Printers & Copiers Logo
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
