Question about Whirlpool 5"x36" White Bathroom Drop-in Bathtub Spa Jet
Jacuzzi outdoor bath tub i have there is power but the bubbles thing isnt working
    Scholar:
  • 80 Answers
Find the plug for the pump and plug it in ( tub full of water), if the pump works,the problem is in the contol box or switch. if the pump/motor has a plastic tube coming out of a black box, and the pump still does not work when plugged in, it is most likely the air switch connected to that plastic tube on the pump. the switch is avaliable online and not to hard to replace if you are mechanically inclined.
Posted on Sep 27, 2009
How to clean a whirlpool bath tub
There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
This should do the job.
Pure Spa Whirlpool Bath Spa and Hot Tub Cleaning Kit
Nov 17, 2015 | Jacuzzi Whirlpool Cetra Whirpool Drop-In...
My new jacuzzi 6 jet tub is only working on one side. What could cause that?
Probably control panel or if there are separate pumps for each side, that side's pump probably doesn't have a relay working with bad switch from the control panel.
Mar 31, 2015 | Whirlpool Jacuzzi Bath Tub with Jets
What cleaner gets the bad smell and crud out of jacuzzi jets?
Here is a link to a site that sells jetted tub cleaners.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Any of these cleaners work very well at removing the smell from a jetted tub and the bacteria in the pipes as well.
Rod
US Parts Center
Mar 15, 2014 | Jacuzzi Home
Need to purchase 2 front panels [white] for Luxura 530 jacuzzi whirlpool bath model N795 also, called skirts
Bath Panels can be very difficult to locate. I would check with your local Jacuzzi Showroom first.
If they are unable to locate the panels you need or they are no longer made then you should head over to Lowes or Home Depot to get a generic panel from one of them and you may need both panels replaced so they match.
rod
US parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Oct 16, 2013 | Jacuzzi Home
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
How to wire a jacuzzi whirlpool tub? What to use for wiring, timer etc?
get an electrician. you need to follow the code for the size of wire to use based on number of amps of the motor and how far away the pump is from the power outlet.
Sep 29, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Stale water odour when jets havent been used on massage type spa
There are several cleaning methods on the internet. I would contact the maker of the tub and see if they have a cleaning agent. I know that Jacuzzi and Aquatic industries have a cleaner that works rather well. I have seen one on the net that uses 2 teaspoons of powder dishwasher soap mixed with bleach. I have not tried this one so don't know how well it works. The ones from the tub companies are not cheap, but if you want something that is going to do the job, spend the money.
Sep 28, 2009 | Hampton Technologies Hampton R -...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Whirlpool 5"x36" White Bathroom Drop-in  Bathtub Spa Jet Logo
227 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
