Question about Dell Inspiron 1545 Notebook
My husband is trying to connect an Arcut cutting printer to his Dell 1545 Inspiron laptop. It says to go to the device manager and select a certain port (Com1 I think). There are no ports in the device manager. He has Microsoft XP home on the laptop because the program requires it. Help?
  • 30 Answers
You have to create ports after you install the printer.
Posted on Sep 26, 2009
How do I turn off the internal mouse pad?
There is no button/ key to turn off Internal Mouse (Touchpad) in a Dell Inspiron 1545 so you may try following the below steps which might help:
    (1)Click start.
    (2)Type device in the search box and select device manager.
    (3)Double click on Mice and other pointing devices.
    (4)Right click on the Internal mouse and select disable.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 22, 2014 | Dell Inspiron 1545 Notebook
Dell inspiron 1545 not charging battery how do I check Motherboard?
If the charger cannot charging is the problem,then you need to repair the Battery management software,because you say that the battery is working,then the error should be on the software,that it doesn't indicate that the battery is charging,first go to Device Manager (Right click My Computer,select Properties,click Hardware,click Device Manager) by type "Device" on the start menu and select Device Manager
Expand the Battery categories and right click on Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
On the Device Manager taskbar, click Scan for hardware changes
Please let me know if it's working
Jul 26, 2012 | Dell Inspiron 15 1545 Notebook
I'm not seeing imaging devices under the device manager...i have an Inspiron 1545... plz help
What are you trying to find?
if you are looking for web camera on a hp or dell it will be under usb in device manager.
Aug 25, 2011 | Dell Inspiron 1545 Notebook
How can i enable blutooth device in dell
Try pressing Fn + F2 and make sure that under your bluetooth options turn discovery on is enabled...
Mar 28, 2010 | Dell Inspiron 1545 Notebook
My dell inspiron 1545 wont connect to linsys-g
Your laptop may have a pre-defined Ip address locked in for your work connection. Did your buddy use the laptop at your place of employment, or was it used at his home? Sometimes an ip is entered manually in the tcp/ip menu locking it to a certain address. To check this opem metwork connections in control panel and right click your wireless device then choose properties and left click. Scroll to the TCP/IP line and go to properties. Make sure everything thereis set to automatic.
Mar 13, 2010 | Dell Inspiron 1545 Notebook
The speed of my laptop when it starts take longer then the desired time....!!! config of my laptop: dell-1545 3 gb ram 320 hd vista home basic
  • Hi, go to the Control Panel, In the Programs category, select the "Change the Startup Programs, only start essential programs at "Boot-Up," you can "stop certain "Services," and "Processes in the (Task Manager) from running during start-up aswell. You may need to "Backup Files, and do a Defragmentation of the HardDrive, open the Computer from the Desktop, select Properties, choose the (Tools), you can use "Clean-up Disk" to make more "Space," all of these will improve the perform, and speed-up the "System." If the solution helped, "rating it is appreciated, thanks."
Mar 07, 2010 | Dell Inspiron 1545 Notebook
Hello sir plz help i have dell inspiron 1545 with processor pentium dual core i am having problem with bluetooth sir i have tryed to install wireless 365 bluetooth modem driver but it is asking me to...
It is very likely that the Dell operator was right and the bluetooth option is not installed on your system. You will have to buy a USB bluetooth dongle or adapter.
click on control panel click on bluetooth devices if its there, is there anything listed as available? also in control panel click on system > device manager and see if any bluetooth devices are listed there. If not you don't have the option built in to your laptop
Jan 13, 2010 | Dell Inspiron 1545 Notebook
Not detecting webcam
You have to reinstall the driver for webcam. You can download it from here> Driver for Webcam
Jun 29, 2009 | Dell Inspiron 1545 Notebook
Dell inspiron 1545 laptop and the same webcam problem.
open your my computer, click on "c" the system will tell you the information is hidden, click on the link and open up the operating system and look in the drivers or there in C and se if you can find you web cam driver, when you find it you might have to force the opening of the driver to install, and once you do that plug your web cam in and see if the system see's it and installs the drivers for the cam, if you installed the driver origanally witht he web cam installed you will have to remove the web cam and unistall the driver and re install it and then plug the web cam back in, and that should help correct the problem.
Jun 22, 2009 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 Notebook Logo
47 people viewed this question
Alun Cox
